Error to create clientraw.txt
xtur
Post by xtur »
Hello
My station is wmr200
I use the wdlive to display data and not leave the temperature and humidity outside most times. I notice that the file is incomplete but clientraw.txt not know why or what may be the reason.
If someone has gone and I can help, I should be grateful.
Attach file clientraw.txt so we can see how it is created, note the wind sensor is disconnected, it is normal not to leave.
[file name=ERRORClientraw.doc size=24576]http://www.meteohub.de/joomla/images/fb ... entraw.doc[/file]
EmjayNet
Re:Error to create clientraw.txt
Post by EmjayNet »
Meteohub only populates a certain amount of data in the clientraw files needed for WDL. WDL does not need all of them to display its information. Meteohub does my clientraw files for WDL and it works well, you can see at www.site-stats.co.uk
You can use the online parser if your clientraw.txt is available to the internet, to see which fields are populated @ http://www.tnetweather.com/wd-parser.php
could you please post a screendump of your sensor settings on "wd live" page of meteohub? May be something is missing there.
xtur
Post by xtur »
I thank you very much for your help.
Finally i found the problem, it was that on page meteohub the weather station, to "hold time for live dates," he put 10 seconds and 300 seconds I made and now it leaves the temepratura.
Again thanks for your help.
