Licensing question
Licensing question
Post by 36260 »
It is said in the 4.5 documentation :
Depending on your Meteohub license, you can connect just one or more weather stations to
Meteohub.
Could you be more specific? I bought one license quite a while ago, does that mean I need to be a new license if for example I have a Vantage Vue and an RFXCOM connected to Meteohub?
Could you let us know how many devices may be attached to Meteohub?
Thank you
Nicolas
Davis VP2 + Solar - Nano SD
HeinrichH
Re:Licensing question
Post by HeinrichH »
As far as I know you can add as much stations you like, I'm running three stations (Vantage, RFXcom and system sensors)
I've asked the same question a while ago and the answer was that you can add the stations you want.
See http://www.meteohub.de/joomla/index.php ... =8&id=3773
Checking the remote....
36260
Post by 36260 »
Thanks for the link it is clear that no add-on license is needed. I intend to add RFScom as well. From where do you get your gear?
HeinrichH is right, I stepped away from the idea to make the number of connected stations part of a licensing model. I will strip the quoted section from the manual.
So enjoy to add as many stations as you like to Meteohub. Your license does cover all that.
browng
Re: Licensing question
Post by browng »
I am trying to get a response to my email to info@meteohub.de regarding the purchase of a license.
Is this the correct email address or there somewhere else I should contacting?
