I am preparing an Asus Eee PC 701 for use with Meteohub. I have Ubuntu 9.1 running from an external USB Hard Drive and have Meteohub 4.6 running inside a vmplayer vm.
I want to install the vmtools to give me control over things like syncing the time between the Ubuntu Host and the vm guest. I read that NTP running inside the vm is not ideal. I notice that it syncs and then unsyncs quite a lot with several time steps, it would be better if NTP on the host was used to sync the guest and for that I understand I need vmtools installed.
I do not appear to be able to see the CDROM with the vmtools on it. The help for vmplayer implies that it should mount automatically.
I hope that someone here has perhaps done this before and can assist.
Many thanks
David
vmplayer 3 installing vmware tools?
Re:vmplayer 3 installing vmware tools?
Well, I have got past the problem of mounting the CDROM and am trying to install the tools but I have run into another problem, there is insufficient space to install in /usr/lib/vmware-tools I need another 190532K. There must be somewhere else that I can install the tools, for example on to the other partition that Meteohub must use for storing the logs etc, but what is the path to that?
Well, I found it - /data, however next problem is that vmware-config-tools.pl needs to compile modules and needs gcc and kernel headers of the running kernel which I don't appear to have. Any idea where I can download the C Header files for the kernel?
OK I used apt-get to install build-essential linux-headers, but it says I already have the newest version. But what is the path to it, that is the question???
headers for your running kernel should be installed by this command:
apt-get install linux-headers-$(uname -r)
Then you can find kernel headers in:
/usr/src/linux-headers-2.6.XX-X-kirkwood/
wehere X depends on the kernel version.
Command 'uname -r' will print version of the kernel you're currently running.
Thanks very much for that.
I have reverted to a fresh meteohub install as I had got in a terrible mess with the attempts to get VMtools installed. I have now managed to get time syncing reasonably with NTP after playing about with some other suggestions, rather than using VMtools to sync the guest from the host.
Weather station is now on test with Meteohub running on the Eee PC.
