I am currently trying out iWDL which is an iPhone Web Application that uses the WDL data files that WDL uploads.
I noticed a couple of minor problems in clientraw.txt:
1. The sign of the longitude is wrong, it should be - for EAST, according to the clientraw.txt info I have found.
2. The separator between the stationname and the time is an underscore where it should be a hyphen.
Example of meteohub generated clientraw.txt, note GM4JJJ_21:50 should be GM4JJJ-21:50
Note -3.484444 should be 3.484444
12345 8.6 8.2 68 2.7 93 1010.0 1.00 1.00 1.00 0.00 0.02 19.0 37 - 20 - - 0 0.0 - - - - - - - - - 21 50 01 GM4JJJ_21:50 0 - 21 01 - - - - - - - -1.1 1.0 5.1 1.9 20 _ 0 8.9 11.4 10.0 9.2 9.5 10.2 7.1 9.4 6.9 6.0 5.2 6.6 7.5 7.4 7.7 7.9 7.4 6.3 4.6 3.9 19.1 1.7 400 21/01/2010 3.0 -0.1 3.5 -3.0 - 8.9 11.4 10.0 9.2 9.5 10.2 7.1 9.4 6.9 6.0 2.6 2.9 3.1 3.1 3.2 4.1 4.6 4.4 4.9 3.9 1.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00 5.1 1.9 2.7 14.8 0 _ _ 112.5 _ 0 - - - - - - - - 19.1 13.5 - 1015.0 1010.0 15.7 _ _ - - 1.7 -0.7 0.0 2010 _ 0 0 0 68 90 90 113 113 113 113 113 113 113 - - 8.6 - 56.066111 -3.484444 - 93.0 69.0 - - !!C10.37Of!!
