clientraw
simonik
clientraw
Post by simonik »
My metohub start produce clientraw.txt, that contain only this : 3.1 m/s
And therefore weather display live cannot use this data. Where is the error? [file name=clientraw.txt size=8]http://www.meteohub.de/joomla/images/fb ... entraw.txt[/file]
YJB
Re:clientraw
Post by YJB »
Just wondering:
Did you select all the sensors that you want to include in the "WD Live" setup section?
In this section you will define the mapping between meteohub sensors and WDL sensors.
simonik
Re:clientraw
Post by simonik »
Yes, I chose all sensors. When I choose in this option "Save", then Meteohub produce complete clientraw.txt and then meteohub revert to produce resize clinentraw.txt Image
YJB
Re:clientraw
Post by YJB »
Hmm, that looks more or less right, have a look at:
/home/meteohub/clientraw.conf
It contains the actual mapping of meteohub sensors to clientraw fields (as well as some conversions), mine is about 4Kb in size, but I guess that will vary on the number of sensors defined
simonik
Re:clientraw
Post by simonik »
Hi, I cannot find directory:home/meteohub/clientraw.conf
My TotalCommander offers me only directory according picture that I enclose. Image
YJB
Re:clientraw
Post by YJB »
I'm really sorry, but forgot to mention that you will need to logon to your meteohub using SSH (or copy the file using SCP), if you are not familiar with UNIX/Linux, this is probably not a good idea.
You can not access the configuration files using the share "..\\public"
simonik
Re:clientraw
Post by simonik »
I am sorry, I use ssh and I get clienetraw.conf. I enclosed it.
simonik
Re:clientraw
Post by simonik »
Thanks, I used WinSCP and I get this file. I am sending
it
simonik
Re:clientraw
Post by simonik »
I used WinSCP and I get this file [file name=clientraw-a4a1e6cebbcd4a33d39ddac645d43843.txt size=4086]http://www.meteohub.de/joomla/images/fb ... d43843.txt[/file]
YJB
Re:clientraw
Post by YJB »
Hmm, your clientraw.conf looks ok to me. Funny thing is that your clientraw.txt doesn't even contain the "header" of the file ("12345"), not sure what is wrong.
I guess that I will need to leave this one to Boris, since I'm more or less out of ideas, you can try to force a recomputation of the data, but I doubt that this will help.
Re:clientraw
clentraw.conf is the template used for generating clientraw.txt file which gets uploaded and displayed by wd-live.
could you give me access on port 7777 to your meteohub? mail to info(at)meteohub.de
simonik
Re:clientraw
Post by simonik »
Hi,I have not public IP. I have started reinstall meteohub. I got a big trouble. RSYNC cannot write backup to the meteohub : read-only file system :-(
Re:clientraw
read-only file sytem is a clear indication of a bad USB stick. You will also find messages about thet in demsg log.
When you call "http://ip-of-your-meteohub/cgi-bin/help.cgi" it will open a ssh tunnel, which I can use to login. No public IP or dyndns needed for that.
Re:clientraw
Tunnel is there but I don't know your pw for http access and ssh access. Please mail to "info(at)meteohub.de".
simonik
Re:clientraw
Post by simonik »
Hello, I bought new USB stick, reinstal Meteohub.
I tried to use rsync - I get message "Read-only". I have to copy files by MSB and by WinSPC. Meteohub is OK. I saw file /etc/rsyncd.conf : there is option read only = yes. I think that it is bad. For restore files by rsynnc it will be read only = no.
I use router and a I cannot givew you address our Meteohub.
Best regards
