1 day less each month?
HeinrichH
Post by HeinrichH »
When I'm using to definition special weather conditions to create a monthly overview of temperatures each month has one day less, according to the attached graph December 2009 has 30 days, January 2010 has 30 days and February has 27 days. Time bucket is 1 month.
Am I doing something wrong? Image
Checking the remote....
Re:1 day less each month?
could you please post your graph definition?
HeinrichH
Post by HeinrichH »
The format string:
set locale "nl_NL"|set timestamp "%d.%m.%y - %H:%M" top|set key below box|set border -1 lw 2
The definition screen is attached. Image
definition looks ok to me. i will check with my data.
schroedi
Post by schroedi »
Have the same problem. Use no own definitions, only the preset.
I am puzzled. For 2008 it looks like this:
Definition here is:
Only difference I can see is the order of entries. Could you please try with high-to-low ordering? This also has the benefit that colors are applied more as expected (blue=cold, red=hot).
If this solves the issue I have a hint what kind of bug I have to search for.
HeinrichH
Post by HeinrichH »
When I'm using this definition, this is the result.
To count the days I only can use the last three months, those are complete, in November 2009 I've installed a battery backup to cover the lots of short power down periods. Image
