simple plug-in example
Periklast
Post by Periklast »
Can someone post a simple plugin-perl code sample for meteohub?
Just an simple script that output for example "sol0 1" each 30 seconds.
I wrote such a perl-script but meteohub doesn't recognize it.
Re:simple plug-in example
Post by skyewright »
Periklast wrote:Just an simple script that output for example "sol0 1" each 30 seconds.
Do you have autoflush set, e.g.
STDOUT->autoflush( 1 );
Boris mentioned why that might be needed in this posting.
If that doesn't help, maybe you could post your script and a screen shot of how you have set up the plug-in on the weather station setup page?
Periklast
Post by Periklast »
My perl code:
#!/usr/bin/perl
use IO::Handle;
while (true){
print "sol0 1\\n";
STDOUT->autoflush(1);
sleep(5);
I run the file in 2 different ways:
./test.pl
or
update-rc.d test.pl defaults
With the last method, the file will run to, but I can't reboot or the after reboot, the webserver can't start anymore.
On the meteohub-webpage, I created a new weather station (Plug-in) and on the sensor-page I created an sol0 sensor with the name "solar".
On that page, I see follow warning:
Warning: Weather station does not have a sensor assigned on "Sensors" page
The meteohub log-files shows:
logger (13.03.2010 11:33:13): connect station 0 (Plug-in via Plug-in).
logger (13.03.2010 11:33:13): unexpected 0 bytes delivered from weather station 0 (Plug-in)
logger (13.03.2010 11:33:13): disconnect station 0 (Plug-in).
Periklast wrote:My perl code:
#!/usr/bin/perl
use IO::Handle;
while (true){
print "sol0 1\\n";
sleep(5);
I'm not sure it's a significant difference, but I have the autoflush outside the loop. It's a "switch" rather than something you need to keep doing.
./test.pl
From the command line that should be fine.
What do you have in the Weather Station setup?
That has me puzzled, as if there is a sensor there for you to assign I'd have thought that meant that the plug-in was working?
Perhaps I'm misunderstanding? Could you post a screen shot?
Periklast
Post by Periklast »
Billy
Post by Billy »
Periklast wrote:This is my screenshot:
http://img690.imageshack.us/img690/9215/tempfi.jpg
I think your plugin path is not what meteohub expects.
It should be something like
/data/plugin/test.pl
where test.pl is your actual perl script.
The perl script is then started by meteohub automatically. And will provide the expected sensor data.
Periklast
Post by Periklast »
Thanks! That's work.
Maybe usefull if that's in the manual..
Periklast
Post by Periklast »
Ah no, it doesn't refresh at the moment. I put an increment "sol 0" -> "sol 1" -> "sol 2" with time-interval of 5 seconds, but only "sol 0" is shown. The "last signal" value becomes larger and larger.
Billy wrote:I think your plugin path is not what meteohub expects.
Yes, the Weather Station setup needs the path as well as the name of the executable file itself.
Periklast wrote:Ah no, it doesn't refresh at the moment. I put an increment "sol 0" -> "sol 1" -> "sol 2" with time-interval of 5 seconds, but only "sol 0" is shown. The "last signal" value becomes larger and larger.
What exactly are you doing in your code?
If exactly as quoted then maybe it's just the lack of a digit after sol. e.g.
my $value = 1;
while (true){
print "sol0 $value\\n";
$value++;
sleep(5);
How's that?
Periklast
Post by Periklast »
If I manually run that code you described, I see the change in my output every 5 seconds.
But meteohub can see only the first value (in this situation, only 0 ). Even if I STDOUT->autoflush(1) in every loop or before the loop.
Periklast wrote:But meteohub can see only the first value (in this situation, only 0 ). Even if I STDOUT->autoflush(1) in every loop or before the loop.
Please post the exact code you are running.
That code may or may not provide the answer, but without it we can only make guesses.
Periklast
Post by Periklast »
Here is my code
#!/usr/bin/perl
use IO::Handle;
my $value = 1;
while (true){
$value++;
sleep(5);
or
#!/usr/bin/perl
use IO::Handle;
my $value = 1;
while (true){
$value++;
sleep(5);
Periklast wrote:Here is my code
On my ALIX-1D
The following works exactly as expected, i.e. providing Meteohub with a value that increments every 5 seconds.
#!/usr/bin/perl -w
use strict;
use IO::Handle;
my $value = 1;
while ( 1 )
    $value++;
    sleep( 5 );
All I've done is
a) Add -w to the first line to turn on warnings.
b) Add use strict;
c) Change true to 1 to placate a warning message.
All of which are largely just a matter of coding style!
Strange...
Periklast
Post by Periklast »
The code above doesn't work for me. Maybe it's because I'm testing within vmware?
Tomorrow, I will test it on my Alix-1D. Thanks!
