dasboard not showing at moment values **solved**
RHead
Post by RHead »
All other values are ok but at moment values are not showing.
RHead
Re:dasboard not showing at moment values..
Post by RHead »
Aah.. again same problem..
Weather Data Logging: running (last data: 11 min)
i booted and logging not running.. no sensor data.
--> reboot now works..
What logs you need figure this out?
Or is it possible to add if no sensor data found in 10mins reboot system?
Chill
Post by Chill »
What version are you using?
I had same trouble, as posted, but updating to version 2.2c it was fixed.
HTH,
Chill
RHead
Post by RHead »
version 2.2d .. now reboot and tryed version 2.2c still no working.. very odd..
RHead
Post by RHead »
Now dashboard is not showing any values.. and wunderground update is not working.. gosh :ohmy:
Post by skyewright »
RHead wrote:version 2.2d .. now reboot and tryed version 2.2c still no working.. very odd..
admin recently warned that 'downgrading' was not a good idea! See
http://www.meteohub.de/joomla/index.php ... 5&catid=14
for the full message.
Re:dasboard not showing at moment values **solved*
This could be tracked down... Root cause was a continuous restart of the logger daemon that inhibits data to be provided correctly for the processes on top of this.
Is fixed with 2.2e.
