blank page
spoetnik
blank page
Post by spoetnik »
I don't know what caused this, but I only get a blank page when going to the administration page. (/cgi-bin/meteohub.cgi)
HTTP-datalogging is still working. Any sugestions??
Thanks in advance.
Re:blank page
If it is a NSLU2 this might be a USB stick problem.
Does "meteohub log" show errors according to bad data in raw data found?
spoetnik
Re:blank page
Post by spoetnik »
Yes, it is a NSLU, and the logs show data errors. Logged by ssh, and checked. /data/logs/meteohub.
Any suggestion what to do? Replace the stick? Then copy the raw data over??
spoetnik
Re:blank page
Post by spoetnik »
Seems like it is still recording raw data. I moved the directory with the troublesome data (201004) and it made a new dir with a raw file in it after the reboot.
Is there a command for the cleanup and check of the raw data??
Re:blank page
spoetnik wrote:Yes, it is a NSLU, and the logs show data errors. Logged by ssh, and checked. /data/logs/meteohub.
yes. Stick will get worse over time. Rescue data as long as you still can.
