Datafile use update 4.6c and 4.6d
HeinrichH
Post by HeinrichH »
After upgrade to 4.6c and later to 4.6d my datafile use increased rapidly from 40% to 65%, see attached graphic.
Normally to file grow was about 1% each week but with this grow the file is 100% in a couple of days.
What is going on?? Image
Checking the remote....
Re:Datafile use update 4.6c and 4.6d
My first guess would be logfile "meteohub log" (/data/log/meteohub.log) reporting socket communication errors. But this is a wild guess.
If my guess is right, just clear the logfile (can be done from web interface).
HeinrichH
Post by HeinrichH »
Thanks for the answer, you're wild guess is right, I've cleared all the log files and the use of the datafile is down to 37%....
HeinrichH
Post by HeinrichH »
After a while the file is growing again with a lot of those errors:
logger (03.04.2010 21:40:42): error while doing accept on socket 5557: Too many open files
Any idea what's the cause of those errors?
Edit 04-04-2010
Just downgraded to update 4.6b because 4.6d caused a lot of errors as above and the signal gap was very high and a lot of communication errors.
This problem occurred on both of my stations
