Problem:
Solar Collector temperature which was today 96 °C
was limited in GNU-Plot to 90°C Maximum.(attachment)
The data itself was correctly logged.
Is this a known limitation?
Thanks for your answers.
1. The maximum value in the graphic definition is not limited (not set)HeinrichH wrote:Did you set the maximum value in the graphic definition to 90°C?
Which plug-in do you use? I'm logging the hot water of my heating with a 1-wire sensor, no problems with the highest temperature of 94°C.
What value are you plotting and using what time buckets?Billy wrote:Solar Collector temperature which was today 96 °C
Not really. At the moment no idea.skyewright wrote: What value are you plotting and using what time buckets?
If you are plotting the basic sensor value then even with the smallest bucket size (5 minutes) there will be some averaging taking place, which will have the effect of 'smoothing' the data. The bigger the time bucket, the greater the smoothing effect.
Could that explain what you are seeing?
