After migration to WMR928 from WMR100
and from NSLU2 to x86-plattform, i decided to inspect some values to make sure everything worked OK !
Look at the enclosed pdf-document
WDlive displayed "Maxwindspeed ever" as 55 m/s 20090715 11:55
Inspected the wind-data for that period, no values at this level found
Marked all data "delete" and did a "recompute"
After this still no change in "Maxwindspeed ever"
Defined a grafh displaying windgust + windgustmin + windgustmax
displaying it and there are a "peek" about 55 m/s
Very strange to me !
I thought "windgustmax" was recalculated after deletion od wind-record for that period of time !
Anyone have a clue ?
Tommy
Highest score "WindSpeed" 57m/s possible ?
Re:Highest score "WindSpeed" 57m/s possible ?
[file name=meteohub.zip size=118137]http://www.meteohub.de/joomla/images/fb ... teohub.zip[/file]
sorry the pdf-file was missing
I think I've a similar problem...
I had some phantom gust of 183,6 Km/h with my WS-2350 station.
This data was recorded somewhere in my meteohub and is my intention to clear it.
I didn't found the wrong data in the raw file...
From port 5558 I read :
day1_wind0_gustspeedmax_time 20100408002837
day1_wind0_gustspeedmax_deg 135
day1_wind0_gustspeedmax_ms 51.0
day1_wind0_gustspeedmax_kmh 183.6
day1_wind0_gustspeedmax_mph 114.1
day1_wind0_gustspeedmax_kn 99.1
day1_wind0_gustspeedmax_bft 15.5
from the web server "Inspect data" menu I read:
20100408002746 wind0 90 0 1 0107
20100408002805 wind0 90 0 1 0106
20100408002828 wind0 90 0 1 0106
20100408002848 wind0 23 0 1 0106
20100408002909 wind0 90 0 1 0107
As you can see, is not present the raw data with time 002837 (the time of the phantom gust)
The same think occours also in the month1 and in the year1 (with other dates&time).
I didn't try to clear any data yet...
Hope someone will help...
Thanks for read.
Giuseppe
Thanks for read.
Giuseppe
raw data is in UTC, time stamp in data from port 5558 is in local time. That might explain, why you have not found it so far ;-)
"Huereka" I´ve found it !
As often the solution to confusing results is simple and easy !
I have found the "error-datapost" located 2hr earlier within raw-data.
For me UTC is 2hr before localtime.
Big THX !
Tommy
Big THX !
Tommy
So far so easy !!!!:laugh:
Great Boris ;)
I've found the errors too!!!
Thanks!!!
Giuseppe
Great Boris ;)
Thanks!!!
Giuseppe
