Sensor last signal "never"
- Senior Boarder
I have an Oregon Scientific WMR100NA with the NSLU2. It's been working fine. Recently however, after restarting following a power interruption it is not receiving any sensor data. Everything is powered up and rebooted and the WMR console is showing data from the sensor units. Not sure what to fix.
Re:Sensor last signal "never"
Hi, I've had the same problem once or twice and the solution for me was to pull the power of the WMR100 even though it seemed like it was working.
but I guess you already tried that?
/L-I
/L-I
- Senior Boarder
You are right. I didn't re-power the WMR because it had batteries - thus never went down I thought - and seemed to be working. I pulled the plug and batteries but that didn't do it. I tried again by rebooting everything including the WMR, the NSLU2, the router and the dsl modem, and that worked! Thanks for the tip!B)
