Nonexistent sensor
cgn
Nonexistent sensor
Post by cgn »
I have a WMR 200 running on Meteohub (4.6 build 67).
In the "sensor" section a sensor (UVN800) appeared
which I haven't got.
I cannot remove the sensor (ID is empty).
How can I remove it ???
Best regards
cgn
Weather Station: Oregon WMR 200
Meteohub-System: SheevaPlug
Since Dec 2009
Re:Nonexistent sensor
Post by skyewright »
cgn wrote:I have a WMR 200 running on Meteohub (4.6 build 67).
Maybe a neightbour has one, or maybe it was just a freak signal?
The last signal was 23 hours ago. Unless you assign an ID to it the sensor it will disappear next time logging is restarted. You can force that to happen on the Maintenance page where you can stop, then restart logging.
cgn
Post by cgn »
AFAIK there is no other weather station around.
I gave an ID to the sensor (uv0), set "Save & Restart Data Logging".
Then I could set the ID to "empty" and the sensor disappeared.
Thanks skyewright!
Best regards
cgn
Since Dec 2009
