problem firmware
Information, issues, requests on Firmware that makes a Meteohub from a NSLU2
maxbon
problem firmware
Post by maxbon »
hi all,
i've bought meteohub in u.s.a.
i downloaded new firmware, but if i try to enter in the hub menu with admin previleges, it doesn't recognize the \"admin\" user and pwd ,
and how can i know my own firmware?
thanks
peteroi
Re:problem firmware
Post by peteroi »
did you already try
user: meteohub
pwd: meteohub ??
BR Peter
Pi/TE923
maxbon
Re:problem firmware
Post by maxbon »
yes but i cannot find advanced menu
binbags
Re:problem firmware
Post by binbags »
Hi
Did you follow the instructions about putting the NSLU2 into the upgrade mode, and did you have a backup of your previous settings and data?
Alan
maxbon
Re:problem firmware
Post by maxbon »
i 've just upgraded version software to 2.0d..
i have linux/slugOS 2.6.16..
and i am very newby to linux language and relatives stuffs...
can someone help me step by step?
thanks
Chill
Re:problem firmware
Post by Chill »
What O.S: are you using?
Are you able to see meteohub in your system? If so, you don't need linux knowledge.
You need to have your PC with an same IP address rang (192.168.1.xx) so you can reach meteohub, which comes with 192.168.1.77 Then you'll be able to change meteohub IP to other desired.
HTH,
Chill
maxbon
Re:problem firmware
Post by maxbon »
i have windows vista ultimate, or home premioum, but i can eventually install a partition with virtualbox of windows xp
however i can see the meteohub in the lan and it is working good,
just i'd like to know how (and if it's necessary) upgrade firmware and how can i see which version i have.
thanks
Re:problem firmware
I can try to guide you through this. please contact me at \"info(at)meteohub.de\".
What might help is, when you give me some information at what step of the instructions outlined here (http://www.meteohub.de/joomla/index.php ... &Itemid=29) you are stuck.
