How to reach Meteohub?
HeinrichH
Post by HeinrichH »
I think I've done something wrong while changing the network address from DHCP to fixed, I can't reach the web interface anymore.
Is there a way to change Meteohub back to DHCP?
Meteohub is running under VMware and I don't know anything of Linux.
It should be reachable at IP 192.168.2.50, see screen shot, but even ping comes with a time out
Checking the remote....
HeinrichH
Re:How to reach Meteohub?
Post by HeinrichH »
Screenshot: Image
I see from the logs that your DNS is also not working.
What is your specified gateway-IP and DNS-IP?
You can find out with "ifconfig" and "cat /etc/resolv.conf"
HeinrichH
Post by HeinrichH »
See attachment, this is as far as I know what I did wrong, I forgot to change the DNS server IP address or so.
The web interface of the other running Meteohub has the following addresses:
Gateway - 192.168.2.1
DNS1 - 212.54.40.25 Image
That is very strange. Without program "ifconfig" your system will have extreme problems, to say the least. Please try "/sbin/ifconfig"
Does "dmesg" give any indication of what had happened?
HeinrichH
Post by HeinrichH »
Attached screen after /sbim/ifconfig
Is there a command I can type in to put the system back to DNS and port 80? Image
HeinrichH
Post by HeinrichH »
The screen after dsmesg Image
nduku
Post by nduku »
in the /sbim/ifconfig screen it says that 192.168.1.77 is still configured, this is the emergency ip if I rember right. Maybe this one works?
HeinrichH
Post by HeinrichH »
I've tried this but also no connection
