Viewing GNU Plot Format Info in Graphs **solved**
patonnet74
Post by patonnet74 »
I've been experimenting with the GNU plot format ability in 2.2d, and it works great.
The only problem is after the format definition has been saved (Correctly and all graphs work correctly) if any of the formatting contains double quotes eg.
set format x \"%a\"
Then all that will display on the graph definition page is anything before the quote e.g
set format x
It's saving fine so looks simply like a formatting issue for display, but it does mean if you want to change anything about the graph definition you would need to retype the whole GNU format each time.
Got to give credit, this is becoming a fantastic application!
Alan
Screenshot Before Saving
Screenshot After Saving
Re:Viewing GNU Plot Format Info in Graph Definitio
The \" bug will be fixed in the next update.
