Weather Underground Rapid Fire not working
Posted: Fri May 07, 2010 6:58 pm
by Rainman32
Using 4.6g Getting this error in alarm log:
weathernet: weather underground rapid fire: no response from weather underground
Re:Weather Underground Rapid Fire not working
Posted: Fri May 07, 2010 7:06 pm
by Rainman32
Whow, don't know why this didn't catch my eye before either, there is now 2 different Rapid Fire checkboxes both above and below Weather Underground settings. The first one is greyed out and can't be checked.
like so:
Weather Underground in "rapid fire" mode. Frequency: every 5 seconds10 seconds15 seconds20 seconds30 seconds45 seconds60 seconds90 seconds120 seconds180 seconds
Weather Underground ID Password
Posted: Sat May 08, 2010 12:38 am
The upper rapid fire entry should read "Weatherflow rapid fire". These are rapid fire settings for weatherflow network.
Will be correctly named with next update.
Hopefully function is ok.
Posted: Sat May 08, 2010 1:08 am
by Rainman32
Ah. Yes, checking Weatherflow enables the first "Weather Underground" Rapid Fire box.
Realize that is just a typo, but perhaps related to Rapid Fire not working for Weather Underground?
Posted: Sat May 08, 2010 10:49 am
WU rapid fire is working fine with my Meteohub. Enabling/disabling weatherflow has no effect on this.
When the message that WU cannot be reached appears just a few times a day, that is no reason for concern. It might have to do with your DSL connection going down for a short term to get a new IP (this is what most consumer DSL connections do in Europe) or it can be caused by some short outages of WU itself.
Caused by the cut down of my DSL connection each night I have about 2 minutes without internet connectivity which results to this messages. I see them every day. Apart from that, no WU connection problems are logged.
2010.05.08 04:00:13 mhfit: weathernet: weather underground rapid fire: no response from weather underground
2010.05.08 04:00:21 mhfit: weathernet: weather underground rapid fire: no response from weather underground
2010.05.08 04:00:32 mhfit: weathernet: weather underground rapid fire: no response from weather underground
2010.05.08 04:00:40 mhfit: weathernet: weather underground rapid fire: no response from weather underground
2010.05.08 04:00:54 mhfit: weathernet: weather underground rapid fire: no response from weather underground
2010.05.08 04:01:00 mhfit: weathernet: weather underground rapid fire: no response from weather underground
2010.05.08 04:01:16 mhfit: weathernet: weather underground rapid fire: no response from weather underground
2010.05.08 04:01:31 mhfit: weathernet: weather underground rapid fire: no response from weather underground
2010.05.08 04:01:39 mhfit: weathernet: weather underground rapid fire: no response from weather underground
2010.05.08 04:01:55 mhfit: weathernet: weather underground rapid fire: no response from weather underground
2010.05.08 04:02:00 mhfit: weathernet: weather underground rapid fire: no response from weather underground
2010.05.08 04:02:20 mhfit: weathernet: weather underground: no response from weather underground
When you get lots of messages over a longer period, then you have to find out what is going on.
Posted: Sat May 08, 2010 1:04 pm
by Rainman32
Thanks. yeah I realized that those messages come nightly when Weather Underground disables Rapid Fire at midnight. there is no interruption of the broadband that I use.
actually haven't gotten those messages since 4/29.. appears to be when it stopped working.
Posted: Sat May 08, 2010 7:07 pm
by Rainman32
I found that the Time Synchonization had stopped for some reason. Went into settings and re-applied. Time Synced and Rapid Fire works again.
just an odd glitch I suppose.
Posted: Tue May 11, 2010 6:28 am
by Edzo1
WU Rapid Fire has stopped working for me too, since updating to ver 4.6g. First time that has happened....,I'll try to reboot and see how it behaves in the am.
Ed
Posted: Tue May 11, 2010 10:58 am
next time this happens, please goto log file page and copy complete contents of "demsg" into a mail to "info(at)meteohub.de",
Posted: Tue May 11, 2010 5:56 pm
by Edzo1
Thanks Boris, will do. The hard reset seemed to work...., Rapid Fire is now working.
Ed
