FTP make no upload
pumma_new
FTP make no upload
Post by pumma_new »
Hy
My FTP Setup is working fine when I test FTP so a Testfile is on the FTP Server.
But the WD Live Date is not uploadet.
I make the Setup for "Grafik uploade" WD-live every minute, but i can find the file only "/public/myweb/uploads/" in copy!
the Alarmlog has no entry.
Please for help.
Markus
Re:FTP make no upload
Is WD-Live working fine inside Meteohub?
Do the files appear on your FTP server? Are you sure about pathes on FTP server? Do you find an actual version of the test-upload file there, when you press "save & test"?
pumma_new
Post by pumma_new »
Hy
WD-Live is working fine local!
No, there is no File on the FTP Server except the Testfile.
I think the Pathes is OK because when i press "save & test" i get a actual version on the FTP Server.
Thanks for your support
Markus
pumma_new
Post by pumma_new »
So, the Probleme is the FTP Server.
I try 4 different FTP Server.
1 hostet on Unix, work fine.
2 hostet on Windows Server, only Testfile is working.
3. FTP Adress: username@ftpadr.xx, no way to communicate with this Way.
4 hostet by world4you.com, is working fine.
Markus
