Deleting records
la9laa
Deleting records
Post by la9laa »
Hi.
I am not able to delete any records/raw data in the inspect data page.
(Example from manual: When you put "20080523165651" in the "from" field and give "+70" into the "seconds" field, then raw data from 23.5.2008 16:56:51 to 16:58:01 will be deleted.)
Reason to delete is error in rain data.
rgds
Re:Deleting records
Post by skyewright »
la9laa wrote:I am not able to delete any records/raw data in the inspect data page.
Did you use the Maintenance page to stop the data logging process before you tried to do the delete?
N.B. The delete option doesn't actually remove any records, it just marks them as deleted - IIIRC you'll see an * next to the records you delete. 'Deleted' records are ignored by the recompute process.
Re:Deleting records
Please also keep in mind, that raw data is time stamped in UTC while graphing is done in local time. So you might have deleted the wrong part of your data?
Jumps in total rain fall should be visible in raw data too, when you look at the last entry of raw data rain, which represents the rain drop counter of your weather station. more details about raw data can be found in appendix of the manual.
la9laa
Re:Deleting records
Post by la9laa »
Thanks. My fault. Had forgotten to stop the data logging :-( Now it works. Records are marked with * I am using copy/paste to delete records.
rgds
Ron..
