clientraw output ** done **
cd0085
Post by cd0085 »
Hi, I've been looking at the format for the clientraw files exported from weather display and was wondering if you'd consider implementing the format into a future version of meteohub so that it can be used with weather display live.
Chris
Re:clientraw output
Post by skyewright »
cd0085 wrote:...so that it can be used with weather display live.
... and with a number of other things too, such as the WxGraphics weather banner scripts and the Ajax/Caterlake weather website scripts.
cd0085
Re:clientraw output
Post by cd0085 »
bump...
Please please, this would be a great feature and the format is well documented so should be too dificult to implement...
G3ZSS
Re:clientraw output
Post by G3ZSS »
I would like to see this implemented as I use both Weather Display Live and WXstickers.
Re:clientraw output
G3ZSS wrote:I would like to see this implemented as I use both Weather Display Live and WXstickers.
I'm interested in seeing clientraw output (as mentioned earlier) but in the meantime I'm already using Meteohub to generate a 'sticker' style csv file that works just fine with the Anole Computer Services WxGraphics script for the banner that I use on Weather-Watch.com and with the Scottish Weather Network for my entry on the map at
http://www.scottishweather.net/
Copy of template file attached... [file name=wx_data.zip size=260]http://www.meteohub.de/joomla/images/fb ... x_data.zip[/file]
Re:clientraw output
WD-Live support will be part of the next update I am working on. As there are four files to fill with an unbelieveable amount of data it will take another week to get this working on an at least experimental level.
However, if you select "Demo" on the menu on the left you will see first results below the well known dashboard.
G3ZSS
Re:clientraw output
Post by G3ZSS »
Excellent news, and I look forward to testing this when it is ready.
Thanks, Peter
