Has anybody tried the YoWindow (http://www.yowindow.com software together with Meteohub?
It supports WD and WsWin so it should work and looks very nice :)
YoWindow/Meteohub
- WS Grave
- Expert Boarder
Re:YoWindow/Meteohub
You need Meteohub to upload an xml-file to your server. Then YoWindow can work with that.
Maybe someone already programmed such an xml-file!?
Because it would be the same for everyone.
Re: YoWindow/Meteohub
has anybody done this ?
i would love to use this feature
it would be so cool if you could export a xml file which yowindow could read.
have a look at thishttp://yowindow.com/ page
you can connect your local weather station instead of the default weather locations as i can see correctly
problem is the export is only done (for now) from weathersoftware like WD and Cumulus.
i would like to use meteohub to upload the xml-file for me.
hope anybody can shine some light on this.
regards,
Marcel
regards,
Marcel
You might try defining an XML template and filling that with data by Meteohub's template mechanism (like for html templates). Feeding that to yowindow should do the trick.
I couldn't get it to run... So I used a ubuntu live distro instead... Some two weeks ago...
we are the pioneers in providing 1z0-146 - exam - questions dumps and mcse - transcender - braindumps.com tutorials with ndm pass guarantee. Download our latest testking www.bgsp.edu questions to pass real exam of mcitp training in Pittsburg State University
Attached a Meteohub / yowindow html to be placed in the meteohub graphs folderadmin wrote:You might try defining an XML template and filling that with data by Meteohub's template mechanism (like for html templates). Feeding that to yowindow should do the trick.
Instruct meteohub to upload it as yowindow.xml
It works OK at at least 30 websites using Meteohub and the Leuven-template.
Example at: demo site
- yowindow.html.zip
- (721 Bytes) Downloaded 617 times
