I'm wondering, does the rainrate change if you use a bigger funnel for your rain gauge?
Or does that have no effect on the calculation of the rainrate!?
Does rainrate change if you use bigger funnel?
Re: Does rainrate change if you use bigger funnel?
If you add a bigger funnel you need to provide a calibration factor on the Settings page of Meteohub.WS Grave wrote:I'm wondering, does the rainrate change if you use a bigger funnel for your rain gauge?
e.g. On my WMR928 I have a funnel that has 4 times the original area, so on the Settings page I have 2 entries for that rain gauge, one applies a factor of 0.25 to "Total Fall" and the other applies a factor of 0.25 to "Rate", with both factors being effective from the date and time when I fitted the funnel.
The WMR928 console itself is unaware of the funnel, so it shows rain as 4 times more than it actually is, so I just need to do a mental calculation if I look at that.
PS. It may be that there are weather station consoles that allow you to set a calibration factor there; if that was the case then you wouldn't need to enter a factor in Meteohub as well.
- WS Grave
- Expert Boarder
Thanks for the confirmation Skyewright.
I was wondering about the high values messured during a recent storm
