Meteoplug Map
Herby
Meteoplug Map
Post by Herby »
My NSLU does not transmit Temperature and Humidity to to the Meteoplug Map! Where is my mistake?
info:
Linux Kernel: 2.6.21.7 266 BogoMIPS, 30 MB RAM, NSLU2 (266 MHz)
MeteoHub: 4.6k (Build 144)
Regards Herby
Re: Meteoplug Map
Post by skyewright »
Herby wrote:My NSLU does not transmit Temperature and Humidity to to the Meteoplug Map! Where is my mistake?
What is the ID for your temperature and humidity sensor?
If it is not th0 then that would explain the omission - but don't worry there is a tweak on the way that will solve this. :D
Herby
Re: Meteoplug Map
Post by Herby »
Thanx for the fast answer!
My ID is th1 - so i have to change all my graphics :-((
Let's begin...
By Herby
half an hour later: I fixed all my graphics :-D Now let's wait and see
SMILE!!! The map it works fine now!!!! :-D :-D
Again- thanx!
Herby
Herby
Re: Meteoplug Map
Post by Herby »
Huuu!
Changed ID back to th1- my graphics discontinue...
How works a "tweak"?
Herby
Re: Meteoplug Map
install 4.6l, which uses sensors selected on your Meteohub "weather network" page as the default sensors for the map.
Re: Meteoplug Map
Herby wrote:Huuu!
"tweak" => "small change".
I should have made it clear that it was a forthcoming change in Meteohub. As you can see from Boris' reply, that change has now been made and is present in version 4.6l :)
Herby
Re: Meteoplug Map
Post by Herby »
I think this tweak won't work for me! On the map my temperature and humidity won't change:
After update i also made an extra reboot, waited for "Wetterdatenneuberechnung:" to be finished!
Always the same values were transmitted.
On "Wetternetzwerke" I send e.g. to Wetterarchiv => everything is ok!
My IDs for temp and hum is th1
Bye Herby
Oh!
A new update "m" is available...i'll try...
Re: Meteoplug Map
could you please send your MAC to "info(at)meteoplug.com"?
I would like to check if your sensor mappings is part of the conf files as expected.
Re: Meteoplug Map
There was a mapping error at the server application. should be fixed by now.
Herby
Re: Meteoplug Map
Post by Herby »
Yes, now it works!
Thank you!
Herb
dls903
Re: Meteoplug Map
Post by dls903 »
Habe gerade gesehen, daß die Höhe in der Karte bei vielen Stationen nicht stimmt wie auch bei meiner Heimstetten
Re: Meteoplug Map
fixed.
dls903
Re: Meteoplug Map
Post by dls903 »
Das war aber eine sehr schnelle Bearbeitung.
Danke das du dir immer soviel mühe gibst
