Update 4.6l
What's hot...
Update 4.6l
Update to Meteohub V4.6l (NSLU2, x86, SheevaPlug) brings these features:
  • Reports sensor IDs used on "weather networks" page as default sensors for outdoor temp, pressure, wind, rain, solar and uv as default sensors to be used with Meteoplug, when a Meteoplug makes use of a default sensor id like "th*", "thb*", "wind*", etc. Using the default sensors in Meteoplug chart definitions will make use of your default sensors, regardless, if there ID number is zero or anything else.
  • Meteoplug map does now make use of default sensors, to get data from stations where default sensors are not mapped to sensor id number zero.
  • Fixes a time zone bug when specifying calibration options.
Link: http://www.meteohub.de/files/update-v4.6l.upd
