Update 4.6m
What's hot...
Update 4.6m
Update to Meteohub V4.6m (NSLU2, x86, SheevaPlug) brings these features:
  • Fixes a bug on some SheevaPlugs that time zone cannot be set
  • Some minor bug fixes with the map and adds "Logger SW" field to the map, which indicates used Meteohub SW.
  • Includes timezone of non-registered Meteohub's into data upload when using Meteoplug. This allows to use correct time zone when displaying Metohub data on Meteoplug maps. Registered Meteoplug users control timezone of Meteoplug via Meteoplug web interface.
  • Fixes problem with handling underscores in wd-live station name.
Link: http://www.meteohub.de/files/update-v4.6m.upd
wfpost
Re: Update 4.6m
Post by wfpost »
Just updated to 4.6m.
On the meteoplug map now it says Stationtype EM1010 which is indeed the last on the list of my connected weatherstations.
VP2 is 1st, RFXCOM 2nd.
But as the EM1010 does not produce any weatherdata a bit misleading.
Is always the station on the bottom of the list with the connected weatherstation used?
Re: Update 4.6m
Good finding! I changed the code in the server application to list all connected weather stations (apart from system data and plugin).
Should be working by now.
Re: Update 4.6m
Post by skyewright »
admin wrote:Good finding! I changed the code in the server application to list all connected weather stations (apart from system data and plugin).
Looking good. :D
Should it maybe exclude weather stations that are "stopped"? I have a WMR-200 on my weather station page for historical reasons, but it is "stopped" (and the WMR-200 console isn't plugged in either; those sensors are picked up by my RFXCOM).
Re: Update 4.6m
Good idea, I reduced list of displayed stations to the ones not being stopped. Should active by now.
Re: Update 4.6m
admin wrote:Good idea, I reduced list of displayed stations to the ones not being stopped. Should active by now.
Yes, the WMR-200 had gone from my map listing when I just checked. Thank you. :)
Re: Update 4.6m
I just got notice that 4.6m has a problem with WD-Live uploads when a station name with a blank is used.
I just applied a hot fix. Updating to 4.6m again (auto update function on maintenance page) should fix this.
andybalt
Re: Update 4.6m
Post by andybalt »
Just re-installed 4.6M using 'check for update' on maintenance panel (currently says build 154 in system info.) My station name, which does contain spaces, is still not appearing in Weather Display Live.
Do I need to download the fixed 4.6m from a specific location?
Re: Update 4.6m
could you please provide a link to your site?
martin150
Re: Update 4.6m
Post by martin150 »
Hi Boris !
Here the same problem !
No stationname only time in WD Live
http://www.hildner.at/meteo
mfG
Martin
andybalt
Re: Update 4.6m
Post by andybalt »
My site is at http://mapaverdesanmiguel.org/weather/c ... ?locale=en
Up until the install of 4.6m the station name appeared to the left of the time stamp at the top left of the weather data. The station name is 'San Miguel De Allende', using spaces between the words.
Re: Update 4.6m
I did another hot-fix. Problem with station name should be solved by now (hopefully).
martin150
Re: Update 4.6m
Post by martin150 »
Hi !
Works very well now !
Thanks !
Martin
andybalt
Re: Update 4.6m
Post by andybalt »
Works for me too - thanks!
FYI, I am having problems with WDL 'records' not being recomputed which may or may not be related to 4.6m. Problem started after adding 4.6m but I also added some old data around that time to get correct 'all time' records. I don't see anything in the logs about recomputation failing - would there be a message?
Guess I will will remove all the older data and see whether that fixes the problem.
Andy
bobball
Re: Update 4.6m
Post by bobball »
After a few weeks of trying to update past 4.6j, I succeeded in updating to 4.6m this morning. I have no idea what I did differently to succeed. I put my Reading MI station on the map, but noticed it's reading 5.9C or so. Temp here is more like 22C. Am I missing something? I don't think I left a sensor in the refrigerator.
