Display problems on WDL
Hugwarrior
Post by Hugwarrior »
Good evening
Since the update 4.6m, I have display problems on WDL.
The data recorded by Meteohub are correct and graphs generated by WDL are also correct!
But the Uv are stuck at 17! and there is a bug in gusts ...
I did not touch any settings before and after the update (WMRS200 + NSLU2).
My father had the same system (WMR100 + NSLU2) also has the same problem since the update to 4.6m.
Here are two sites available online (the second being that of my father)
http://mameteopartout.free.fr
http://mameteomirande.free.fr
Thank you for your help.
Re: Display problems on WDL
Sorry, that is a bug in 4.6m which appears when blanks are used in station names. I will make a hot-fix which fixes this.
You can circumvent this by using "_" as delimiter between the words in the station name instead of space
(will be displayed as space in WD-Live anyway).
Hugwarrior
Ok, thank you for your quick response ...
I'll wait for the hot-fix.
Your product is really great, the map of weather stations is really a great idea!
Good luck for the future. :wink:
