Solar display problems with WDLive
birdfeedr
Post by birdfeedr »
Uploading the 4 files for WDLive has been working for a while, but I noticed the Solar instrument displays a value, but the Solar graphs are flatline. Julian took a look and saw problems in the clientraw files. Initially, the 4 clientraw text files were simply set to upload. Since then, I clicked to save them in public/myweb/uploads.
Questions: Can these files be recreated from logged data? In case there was a data flaw, can it be fixed?
If they are *not* specified to be saved in public/myweb/uploads, where are they when the onboard WDLive panel is displayed? Do the clientraw files reside somewhere else as well?
meteohub [on fit-PCslim] with VPro Plus
http://www.elbedo.com/weather/wx.htm
Update: Solar Last 7 Days graph is now good where it was not previously, although Solar Last 24 Hours is still flatline.
More update: Searching forum topics for clientrawhour.txt, I find there are previous reports of solar graphing problems. The 5.04 version of WDLive embedded in meteohub works properly, while 6.05 version displays improperly, due to changes made in WDLive.
Boris, I'm open to suggestions.
