Vantage Pro2/Vue forecast messages
Hi to all!
Is there a way to translate the forecast messages of the Vantage Vue (and the VP2, I presume) in other languages?
Thanks for your answers.
Mauro
Mauro
Re: Vantage Vue forecast messages
Hi Boris.
Can you please tell me if is it possible to translate the Vantage Vue/Pro2 forecast messages in Italian with the same procedure used to translate the same messages in German?
If you need, me and others italian users can help you.
Best regards.
Mauro
Best regards.
Mauro
Re: Vantage Pro2/Vue forecast messages
Ciao a tutti.
In attesa di una risposta spero affermativa di Boris, se c'è qualcuno che ha già qualcosa di pronto o da affinare, si faccia avanti!
La traduzione non sembra particolarmente complessa ma 4, 6 o 8 occhi sono meglio di due...
Salutoni.
Mauro
Salutoni.
Mauro
this are the strings to change to italian...
char *vantage_fc_rule[] = {
"Mostly clear and cooler."
, "Mostly clear with little temperature change."
, "Mostly clear for 12 hours with little temperature change."
, "Mostly clear for 12 to 24 hours and cooler."
, "Partly cloudy and cooler."
, "Partly cloudy with little temperature change."
, "Mostly clear and warmer."
, "Increasing clouds and warmer. Precipitation possible within 24 to 48 hours."
, "Increasing clouds with little temperature change. Precipitation possible within 24 hours."
, "Increasing clouds with little temperature change. Precipitation possible within 12 hours."
, "Increasing clouds and warmer. Precipitation possible within 24 hours."
, "Mostly clear and warmer. Increasing winds."
, "Increasing clouds and warmer. Precipitation possible within 12 hours. Increasing winds."
, "Increasing clouds and warmer."
, "Mostly clear and warmer. Precipitation possible within 48 hours."
, "Increasing clouds with little temperature change. Precipitation possible within 24 to 48 hours."
, "Increasing clouds with little temperature change."
, "Increasing clouds and warmer. Precipitation possible within 12 to 24 hours."
, "Increasing clouds and warmer. Precipitation possible within 12 to 24 hours. Windy."
, "Increasing clouds and warmer. Precipitation possible within 6 to 12 hours."
, "Increasing clouds and warmer. Precipitation possible within 6 to 12 hours. Windy."
, "Increasing clouds and warmer. Precipitation possible within 12 hours."
, "Increasing clouds and warmer. Precipitation likley."
, "Clearing and cooler. Precipitation ending within 6 hours."
, "Mostly clear and cooler."
, "Mostly cloudy and cooler. Precipitation continuing."
, "Mostly cloudy and cooler. Precipitation likely."
, "Mostly cloudy with little temperature change. Precipitation continuing."
, "Mostly cloudy with little temperature change. Precipitation likely."
, "Increasing clouds and cooler. Precipitation possible and windy within 6 hours."
, "Increasing clouds with little temperature change. Precipitation possible and windy within 6 hours."
, "Mostly cloudy and cooler. Precipitation continuing. Increasing winds."
, "Mostly cloudy and cooler. Precipitation likely. Increasing winds."
, "Mostly cloudy with little temperature change. Precipitation continuing. Increasing winds."
, "Mostly cloudy with little temperature change. Precipitation likely. Increasing winds."
, "Increasing clouds and cooler. Precipitation possible within 12 to 24 hours possible wind shift to the W, NW, or N."
, "Increasing clouds with little temperature change. Precipitation possible within 12 to 24 hours possible wind shift to the W, NW, or N."
, "Increasing clouds and cooler. Precipitation possible within 6 hours possible wind shift to the W, NW, or N."
, "Increasing clouds with little temperature change. Precipitation possible within 6 hours possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation ending within 12 hours possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation ending within 12 hours possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation possible within 24 hours possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation possible within 24 hours possible wind shift to the W, NW, or N."
, "Clearing, cooler and windy. Precipitation ending within 6 hours."
, "Clearing, cooler and windy."
, "Mostly cloudy and cooler. Precipitation ending within 6 hours. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation possible within 12 hours. Windy."
, "Increasing clouds and cooler. Precipitation possible within 12 hours, possibly heavy at times. Windy."
, "Mostly cloudy and cooler. Precipitation ending within 6 hours. Windy."
, "Mostly cloudy and cooler. Precipitation possible within 12 hours. Windy."
, "Mostly cloudy and cooler. Precipitation ending in 12 to 24 hours."
, "Mostly cloudy and cooler."
, "Mostly cloudy and cooler. Precipitation continuing, possible heavy at times. Windy."
, "Mostly cloudy and cooler. Precipitation possible within 6 to 12 hours. Windy."
, "Mostly cloudy with little temperature change. Precipitation continuing, possibly heavy at times. Windy."
, "Mostly cloudy with little temperature change. Precipitation possible within 6 to 12 hours. Windy."
, "Increasing clouds with little temperature change. Precipitation possible within 12 hours, possibly heavy at times. Windy."
, "Mostly cloudy and cooler. Windy."
, "Mostly cloudy and cooler. Precipitation continuing, possibly heavy at times. Windy."
, "Mostly cloudy and cooler. Precipitation likely, possibly heavy at times. Windy."
, "Mostly cloudy with little temperature change. Precipitation likely, possibly heavy at times. Windy."
, "Increasing clouds and cooler. Precipitation possible within 6 hours. Windy."
, "Increasing clouds with little temperature change. Precipitation possible within 6 hours. Windy"
, "Increasing clouds and cooler. Precipitation continuing. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation likely. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation continuing. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation likely. Windy with possible wind shift to the W, NW, or N."
, "Increasing clouds and cooler. Precipitation possible within 6 hours. Windy with possible wind shift to the W, NW, or N."
, "Increasing clouds with little temperature change. Precipitation possible within 6 hours. Windy with possible wind shift to the W, NW, or N."
, "Increasing clouds and cooler. Precipitation possible within 12 to 24 hours. Windy with possible wind shift to the W, NW, or N."
, "Increasing clouds with little temperature change. Precipitation possible within 12 to 24 hours. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation possibly heavy at times and ending within 12 hours. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation possible within 6 to 12 hours, possibly heavy at times. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation ending within 12 hours. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy with little temperature change. Precipitation possible within 6 to 12 hours, possibly heavy at times. Windy with possible wind shift to the W, NW, or N."
, "Mostly cloudy and cooler. Precipitation possible within 12 hours, possibly heavy at times. Windy."
, "FORECAST REQUIRES 3 HOURS OF RECENT DATA"
};- YJB
I've supplied the Dutch translations to Boris.
Ysbrand
Ysbrand
Hi Boris.
Please find attached the italian translation.
Best regards.
Mauro
Best regards.
Mauro
- VP_Forecast_Italian.zip
- (956 Bytes) Downloaded 502 times
next version will have additional forecast texts in Italian (actual_thb0_fc_textit) and Dutch (actual_thb0_fc_textnl).
WD-Live will be feeded with the forecast in the language choosen on the Meteohub "Dashboard" page. AT the moment just German, English, Italien and Dutch are supported. Other Language selections will be mapped to English.
Great!
Thanks Boris!
Mauro
Thanks Boris!
Mauro
Hi Boris.
Please find attached a new release of the italian translation with some minor changes.
Best regards.
Mauro
Best regards.
Mauro
- (953 Bytes) Downloaded 498 times
Anywhere I can manually translate this myself? Or is the procedure different now? Because if I change language at the dashboard-page to f.ex Italiano the forecast is still in English.
Please if anyone can help me out here.
I am sure these files is accessible via ssh, so I can translate f.ex the Italiano-version to Norwegian and then choose Italiano at the Dashboard-page.
- meteo-quimper
- Junior Boarder
Hi Boris
It is possible to add French language translation for: VP2 forecast, moon phase, wind direction....
I can send you the translation, it is possible that i add them directly to Meteohub ?
yes, please send me the file, info(at)meteohub.de
