sheevaplug & wmr928 - looses senzors :s
urosh
Post by urosh »
Hello.
Before I had this same weatherstation connected to a nslu2. As we has a storm and the nslu2 died, I bought the sheeva.
I installed everything and everything is working. Not really. Meteohub works as it should (maybe?) and it also found my station. The problem is, that it just randomly looses the connection to the sheeva, as I see that there in the sensor page it just says in last singal "never". But there was a signal - as I can see in the logs. It just happens randomly and I don't know where/what to look at. The station is at home and is working (was every time I checked - sensors are sending data to it) and nobody touched the station/sheeva. And in meteohub the sensors are just not shown anymore.
Did someone had something like this? Should I reimage everything and try again? I just don't understand this :s...
Boris, please help :)
I can give you the access to the box if needed.
Cheers, Uros.
urosh
Re: sheevaplug & wmr928 - looses senzors :s
Post by urosh »
in the /data/log/meteohub.log I found this:
logger (17.09.2010 11:20:47): no signal from station 0 (WMR-928) for 150 seconds, station to be restarted.
logger (17.09.2010 11:20:47): disconnect station 0 (WMR-928).
logger (17.09.2010 11:21:17): connect station 0 (WMR-928 via USB serial).
logger (17.09.2010 11:23:48): no signal from station 0 (WMR-928) for 150 seconds, station to be restarted.
logger (17.09.2010 11:23:48): disconnect station 0 (WMR-928).
logger (17.09.2010 11:24:18): connect station 0 (WMR-928 via USB serial).
logger (17.09.2010 11:26:49): no signal from station 0 (WMR-928) for 150 seconds, station to be restarted.
logger (17.09.2010 11:26:49): disconnect station 0 (WMR-928).
logger (17.09.2010 11:27:19): connect station 0 (WMR-928 via USB serial).
and the data was:
I don't know what is going on here...
Lybbe
Post by Lybbe »
Same problem here using sheeva and WMR928.
This happens whenever i reboot my sheeva. What i have to do to fix this is to delete the weatherstation in meteoplug and add it again + sensors. Makes no sense to me, but it works.
If my sheeva dies of poweroutage it won't connect to the weatherstation until i get home and do the procedures above.
Boris, any idea what this is all about?
can you give me remote access on ports 22 and 7777?
please send login details to info(at)meteohub.de.
cheffy
Post by cheffy »
Did this problem ever get resolved because I have the same issue.
I am just got a meteo sheeva which had Meteohub pre-installed ready to go, however I am struggling to get it up and running.
I am following the set-up guidelines and I have managed to find the IP address and log into Meteohub. I have selected my weather station WMR-928, however I am having real trouble trying to connect to my sensors. Sometimes Meteohub does not pick them up or on the odd occasion it does find one it takes a long time to update or drops out (last signal never).
Does anybody have any ideas??
markhiseman
Post by markhiseman »
Could it be related to this?
viewtopic.php?f=25&t=6759
yes, version 4.6v should have this fixed.
Wessel
Post by Wessel »
I have almost the same problem with my Sheevaplug and WMR200. It was working fine during some days then the sensors started to loose signal in the Meteohub. Some times it takes 30 min, sometimes more to return the signal. In the display the sensor are working fine, only in Meteohub looses signal. I did the last uptade of meteohub.
Should I delete weather station e install it and all sensors again or replace USB cable? Or is ther another solution?
I dont think it has something to do with the software.
Changing USB cable and console location to optimize RF range might be worth a try.
Wessel
Post by Wessel »
I changed USB cable and console location and since last night seems to be working fine. Thanks.
Wessel
Post by Wessel »
Boris, I changed the weather station and display's location to another place and I already bought 3 kinds of USB cable but the sensors doesn't work. Two days ago the weather station worked fine during one day, just some times it took 20, 30 minutes to send another signal, however yesterday stopped to work and today is the same.
All sensor are working in the display, I can add the weather station on meteohub but in the sensors page, in last signal, it's said "never". Is there a special kind of USB cable that would fix this problem or what can I do? I'm facing this problem since 6 month ago... :(
Wessel
Post by Wessel »
Wessel wrote:Boris, I changed the weather station and display's location to another place and I already bought 3 kinds of USB cable but the sensors doesn't work. Two days ago the weather station worked fine during one day, just some times it took 20, 30 minutes to send another signal, however yesterday stopped to work and today is the same.
The display and rain sensor are working fine, almost each minute the signal is updated. The wind sensor isn't working, no signal since 3 days ago. The temperature sensor works, but some times takes more then 30 min to update the signal. Remember, the display shows all sensors perfectly. Please, if someone can help me with this problem...
can you please browse to "http://lan-ip-of-your-meteohub/cgi-bin/help.cgi"?
This should allow me to login and do some checks.
Wessel
Post by Wessel »
admin wrote:can you please browse to "http://lan-ip-of-your-meteohub/cgi-bin/help.cgi"?
Ok, it's done.
I have access to a sheevaplug with a wmr-200 connected. Is that yours?
I see that outdoor sensors dropping off very often. As wmr-200 is known
to be not the best performer in RF reception, I would recommend to place
the sensors closer to the console and to put them into some height
(near the ground a lot of RF signal strength gets lost into ground).
As there are also lots of USB errors, changing USB cable path and using
a short, well shielded cable might also help.
I also increased timeout value for sensor age from 300 secs to 600 secs
(datahold value on weather station page) which should make it a bit more
tollerant when sending slightly aged data to weather networks.
All that are normal issues, when you are at limits with RF reception. sorry.
