WDL forecast
Posted: Wed Sep 29, 2010 7:29 pm
by Heuer
Although Meteohub updates WDL it shows the forecast as 'undefined'
Is there a setting that will allow the Davis VP forecast to be forwarded? It used to work when I uploaded data via Weather Display.
David
Re: WDL forecast
Posted: Thu Sep 30, 2010 2:51 pm
by d_l
Try setting:
<showDavisForecast>0</showDavisForecast>
in the WDLconfig.xml file to see if that works.
Re: WDL forecast
Posted: Thu Sep 30, 2010 5:30 pm
by Heuer
Already set to <0>. The forecast is there when I feed WDL from WD. Wonder whether Meteohub ignores the Davis Forecast?
Re: WDL forecast
Posted: Thu Sep 30, 2010 5:49 pm
by d_l
As a next step, check to see if you have a text forecast for the meteohub's clientraw output:
http://www.tnetweather.com/wd-parser.php -- item 49.
WDL does post the VP2 text forecasts on my web pages so this isn't a bug problem with meteohub, but must be a specific configuration problem.
Re: WDL forecast
Posted: Fri Oct 01, 2010 8:11 pm
by Heuer
Thanks - I will run the Clientdraw parser on the Metohub output. Currently I am connected to Weather Display which shows the following:
049 Weather Desc L Night time/Moderate drizzle
Once the "moderate drizzle" stops I will reconnect Meteohub and see what that says.
Re: WDL forecast
Posted: Mon Oct 04, 2010 2:23 pm
by Heuer
Having just upgraded to the latest f/w the forecast has appeared:
048 Icon Type Z 19 (Partly Cloudy)
049 Weather Desc L Increasing clouds with little temperature change.
However the current conditions and forecast are showing the same message!
Normally I would expect to see 'partly cloudy' as the current condition. Any thoughts?
