3 beeps but IP address assigned...
eightbysix
Post by eightbysix »
Just installed on my NSLU2. When I start it up, I get 3 beeps (once the green light is steady).
The manual says this means it couldnt get an IP address, although the router has assigned one to it (I can tell due to its mac address)
I get a reply when ping the IP address, but the web admin page wont load.
Any ideas?
Re: 3 beeps but IP address assigned...
looks like a not correctly setup usb stick. did you use physical disk option with diskimage when selecting target drive?
eightbysix
I used the 2 usb sticks method on the NSLU2 - one smaller one with the .rar file on, and the other an empty 4Gb stick
eightbysix
Does this help? It's the log file from the 'small' usb stick:
stickit started.
Thu Sep 30 15:43:17 UTC 2010
accepted file:/media/sda1/meteohub-v4.6i-4GB.rar
waiting for target stick ... found.
unrar and copy /media/sda1/meteohub-v4.6i-4GB.rar to /dev/sdb/ ...
7741212+388 records in
7741212+388 records out
done.
shutdown
here is the IPLog:
eth0      Link encap:Ethernet  HWaddr 00:04:5A:0F:9D:88
          inet addr:192.168.1.13  Bcast:192.168.1.255  Mask:255.255.255.0
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:23 errors:0 dropped:0 overruns:0 frame:0
          TX packets:3 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:100
          RX bytes:2109 (2.0 KiB)  TX bytes:1222 (1.1 KiB)
eth0:0    Link encap:Ethernet  HWaddr 00:04:5A:0F:9D:88
          inet addr:192.168.1.77  Bcast:192.168.1.255  Mask:255.255.255.0
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          UP LOOPBACK RUNNING  MTU:16436  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
Should I be able to read the contents of the 4Gb stick when plugged into my windows PC? (I cant).
eightbysix
Aha - I downloaded the image and wrote it to theUSB stick via my PC. Seems to work now.
Trouble is, the version has expired. I try to download the auto update (says 4.6p is available) but when I try to install it, there is no difference. Checking for new version sends me around the loop again.
4.6q is now avail...
