Hallo Boris,
Wäre es möglich, das Meteohub bei Ausfall eines Sensors (z.b. Temperatur th0) automatisch auf einen anderen Sensor umschaltet (th1)??
Grüsse vom Bodensee
Stefan
Automatische Sensorumstellung
- YJB
Re: Automatische Sensorumstellung
Yes, you can define a virtual sensor:
Failover
When designing a failover mechanism, you need to define a master (which provides data to the virtual sensor during normal operation) and a slave, which provides data instead of the master sensor, when the master has not been sending data for a certain amount of time. To make this definition your have to make two entries in virtual sensor section for the new ID.
The meteohub manual has all the details
Failover
