License-Problem after upgrade to 4.6t
Posted: Thu Dec 02, 2010 7:39 pm
by zunshiner
after upgrading to 4.6t I cannot start the data logging process anymore as meteohub log says "logger (02.12.2010 17:48:58): Demo license timed out. Please contact "
info@meteohub.de" to get a valid license."
But my activation key is valid and entered on the maintenance page.
Any ideas?
Mathias
Re: License-Problem after upgrade to 4.6t
Posted: Fri Dec 03, 2010 10:17 pm
please update to 4.6u
Posted: Fri Dec 03, 2010 11:09 pm
by zunshiner
did the upgrade to 4.6u
Unfortunately problem still exists.
Posted: Sat Dec 04, 2010 12:26 am
can you give me access on ports 22 and 7777?
Posted: Sat Dec 04, 2010 12:37 am
by zunshiner
opened ssh tunnel to meteohub support
war es das oder wie mache ich das?
Posted: Sat Dec 04, 2010 1:03 am
Please update again to 4.6u. Should be fixed by now.
Posted: Sat Dec 04, 2010 1:07 am
by zunshiner
ok, will try
for which ip should i open ports?
Posted: Sat Dec 04, 2010 1:12 am
if the new 4.6u works, I don't need ports anymore.
Posted: Sat Dec 04, 2010 1:14 am
by zunshiner
updated to 4.6u (build 200)
sensors are now working again
Weather data logging is running again.
Thanks for your help.
Still curious though which IP i should have used to open the ports to.
Greets
Mathias
Posted: Sat Dec 04, 2010 1:18 am
When you forward ports 22 and 7777 on your router to the LAN IP of your meteohub and tell me the WAN IP of your router, I could login to your Meteohub via ssh and http. But it looks to me as this is not needed in your case anymore.
Posted: Sat Dec 04, 2010 1:20 am
by zunshiner
yes, it looks fine now.
Again, Thanks for your help.
Posted: Sat Dec 04, 2010 12:34 pm
by Stachi
Hallo Boris
Ich habe einen zweiten Meteohub im Test, dieser ist mit dem lizenzierten Meteohub gekoppelt (daisy chained). Es kommt die Meldung:
Demoversion ist beendet, da mehr als 3 Monate Daten aufgezeichnet wurden.
Demoversion ist abgelaufen. Zum weiteren Betrieb ist ein Aktivierungscode erforderlich
4.6u lässt sich nicht mehr installieren.
Die Meldung ist nachvollziehbar, da im lizenzierten Hub Daten > 3 Monate anliegen, welche der zweite Hub zieht. Dieser ist jedoch noch keinen Monat in Betrieb.
Gibt es hier auch eine Möglichkeit für eine Erweiterung der Testlizenz?
Danke und Gruss, Gion
Edit: Ziehe meine Frage zurück. Ursache war wohl, dass ich manuell die RAW-Daten in den 2. Meteohub kopiert hatte.
