NTP not syncing?
WebDog
NTP not syncing?
Post by WebDog »
Running 2.2d for almost a week now and noticed in the ntp client log
....snip ntp.log ......
1 Apr 23:32:48 ntpdate[972]: step time server 81.216.247.88 offset 1.604340 sec
1 Apr 23:32:50 ntpd[1058]: frequency initialized 10.009 PPM from /var/spool/ntp/ntp.drift
1 Apr 23:36:04 ntpd[1058]: synchronized to 192.53.103.108, stratum 1
1 Apr 23:36:04 ntpd[1058]: kernel time sync enabled 0001
1 Apr 23:55:26 ntpd[1058]: synchronized to 192.53.103.104, stratum 1
2 Apr 00:12:34 ntpd[1058]: synchronized to 192.53.103.108, stratum 1
Interestinly it seems that the unexpected bytes message ends about the very same time ntp messages ends in the log!
.....snip meteohub.log ....
logger (02.04.2008 00:05:26): unexpected bytes while syncing to record: 00 ff ff 7f 00 00 ff ff 00 00 00 00 01 00 00 00 00 00 00 00 ff ff ff ff ff ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1f 03 03 bb 6e 02 96 07 2a 49
logger (02.04.2008 00:07:00): unexpected bytes while syncing to record: 00 00 ff ff 00 00 00 00 01 00 00 00 00 00 00 00 ff ff ff ff ff ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1f 03 03 bb 6e 02 96 07 75 e5
logger (02.04.2008 00:08:33): unexpected bytes while syncing to record: ff ff 00 00 00 00 01 00 00 00 00 00 00 00 ff ff ff ff ff ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1f 03 03 bb 6e 02 96 07 ad c1
logger (02.04.2008 00:10:06): unexpected bytes while syncing to record: 00 ff ff 00 00 00 00 01 00 00 00 00 00 00 00 ff ff ff ff ff ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1f 03 03 bb 6e 02 96 07 6c 5d
logger (02.04.2008 00:11:39): unexpected bytes while syncing to record: 00 00 ff ff 00 00 00 00 01 00 00 00 00 00 00 00 ff ff ff ff ff ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1f 03 03 bb 6e 02 96 07 cf 43
logger (02.04.2008 00:13:12): unexpected bytes while syncing to record: ff ff ff 00 00 ff ff 7f 00 00 ff ff 00 00 00 00 01 00 00 00 00 00 00 00 ff ff ff ff ff ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1f 03 03 bb 6e 02 96 07 1f 8f
logger (02.04.2008 00:14:46): unexpected bytes while syncing to record: ff ff 00 00 00 00 01 00 00 00 00 00 00 00 ff ff ff ff ff ff ff 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1f 03 03 bb 6e 02 96 07 1c 1d
These are the last entries in the log
Other than that everything seems OK, and I cannot see that the system time is off by any noticable amout of time!
/Lasse
Re:NTP not syncing?
ntp on the new kernel is not making many noise it is synchronized once. So that is ok.
I drilled down verbosity of the logger, but i guess that needs installation of an update to apply...
