The saratoge (ajax) scipts are made to readout the clientraw.txt. But not all fields are available in this file.
http://saratoga-weather.org/scripts-WD-AJAX-PHP.php
Is there already someone that modify this script so that it can read the allsensors file?
gr Geert
www.hetweerinboskamp.nl
saratoga script read allsensors file?
Re: saratoga script read allsensors file?
clientraw.txt and allsensors are different things in quite a number of ways, so it's not a like for like comparison.AenG wrote:The saratoge (ajax) scipts are made to readout the clientraw.txt. But not all fields are available in this file.
One difficulty would be that the contents of the clientraw.txt file are well defined and consistent (i.e. fixed), but everyones allsensors is different because everyone has a different set of sensors...
Actually the saratoga scripts use other files too, e.g. testtags.php and trends-inc.html. There has already been an attempt to drive saratoga pages from Meteohub by Meteohub user mghens. I seem to recall that it was at last partially successful. Here's a link to a topic where it was discussed:
viewtopic.php?f=20&t=3135&p=4192&hilit= ... .php#p7091
