Is it possible to upgrade the current debian etch distribution to debian lenny without problems with meteohub?
When trying to install some programs (like fuse for 1-wire), we have to update the repositories (apt-get update). But debian etch is outdated en the repositories don't exists anymore.
Debian etch to lenny
- YJB
Re: Debian etch to lenny
I've double checked with Boris, and this is not possible at this moment. (Actually, if you try it, you will most likely run out of filesystem space as well)
The upgrade form etch to Lenny is in the pipeline for a future release (Sheeva is already running Lenny), but it's a tremendous effort, since the x86 release covers multiple platforms (Alix Ebox, VMware etc).
xor
- Fresh Boarder
upgrade etch to lenny (x86 platform)
update is not difficult but requires extra space
to download the update, let it be a usb flash.
customizable keyboard for your convenience:
# kbd-config
see how the system sees our additional usb flash
# fdisk-l
Disk / dev / sda: 8024 MB, 8024752128 bytes
OK, the disk is seen as sda, continue ...
packs are loaded into the / var / cache / apt / archives
assemble this kaktalog additional disk space:
# mount / dev/sda1 / var / cache / apt / archives
it will create a folder to download the packages:
# mkdir / var / cache / apt / archives / partial
Now otredaktirum file package sources:
# nano / etc / apt / sources.list
change everything etch to lenny
(You can add or change the repository)
try to upgrade:
# aptitude update
get an error> NO_PUBKEY 9AA38DCD55BE302B
add a key:
# gpg - keyserver wwwkeys.eu.pgp.net - recv-keys 9AA38DCD55BE302B
# apt-key add / root / .gnupg / pubring.gpg
Conduct a preliminary update:
# aptitude update
Next install packages for Lenny update:
# aptitude install dpkg aptitude apt
Make a minimal upgrade:
# aptitude upgrade
If all goes well, then do a full update:
# aptitude full-upgrade
umount our flash
# umount / var / cache / apt / archives
Reboot:
# reboot
And check the version
$ cat / etc / debian_version
5.0.7
# kbd-config
# fdisk-l
try to upgrade:
# aptitude update
add a key:
# aptitude update
# aptitude upgrade
umount our flash
Reboot:
# reboot
5.0.7
I have followed all the instructions "upgrade etch to lenny (x86 platform)".
The upgrade was completelly succesfull. Great description.
The system is now 5.0.10.
meteohub:~# cat /etc/debian_version
5.0.10
However it did not help. Wifi functionality is still not available even after system upgrade.
meteohub:~# lspci
00:0c.0 Ethernet controller: Atheros Communications Inc. AR5413 802.11abg NIC (rev 01)
It is strange. Could you help me please. Any idea or advice?
Thank you.
5.0.10
meteohub:~# lspci
Thank you.
xor
- Fresh Boarder
I do not remember the size of the new kernel, you may have to delete the old one.
do not forget about the folder / var / cache / apt /, it must be on a different drive.
system disk is very small
upgrade kernel 3.8.13-voyage
nano /etc/apt/sources.list
deb http://www.voyage.hk/dists/experimental ./
deb http://www.voyage.hk/dists/unstable ./
deb http://www.voyage.hk/dists/0.9 ./
wget http://www.voyage.hk/dists/experimental/archive.key -O - | apt-key add -
aptitude update
aptitude install linux-image-3.8.13-voyage
upd
I tried to install the new kernel on the old system, the script worked with two errors in /boot /grub/menu.lst and not created initrd.img
after installing a new kernel before reboot fix /boot /grub/menu.lst
title Debian GNU / Linux, kernel 3.8.13-voyage
root (hd0, 0)
kernel /boot/vmlinuz-3.8.13-voyage root = /dev/hda1 ro quiet
initrd /boot/initrd.img-3.8.13-voyage
and copy the initrd.img-3.8.13-voyage in the folder /boot
http://yadi.sk/d/lYZGcPFSFK2ud
aptitude update
upd
root (hd0, 0)
Georgecamp
- Fresh Boarder
We've two times checked out along with Boris, along with this is not achievable at this moment. (Actually, when you try it out, a person will most likely run out regarding filesystem space seeing that well)Your upgrade style etch to help Lenny is this pipeline to get a future release (Sheeva has already been jogging Lenny), however it is a great attempt, because the x86 release handles multiple platforms (Alix Ebox, VMware etc).Periklast wrote:Is it possible to upgrade the current debian etch distribution to debian lenny without problems with meteohub?
We are the pioneers in providing mybraindumps.net and Metropolitan College of New York exams with 100% exam pass guarantee. Download our latest Intel and University of California, San Francisco or pass real exam of Youtube.
