Problem with mini maxi
atlantique44
Post by atlantique44 »
Good evening
This is a translation of the french to English.
I'm sorry, but I can not write or read English
I do not understand my curve minimum and maximum temperature are the same and when the export file WSWIN in mini and maxi I'm a zero
J have a station vp2
Meteohub
Wswin
YJB
Re: Problem with mini maxi
Post by YJB »
Can you show us your graph definition? A screen capture would work, or, ideally the contents of the __test.mg file. You can find this file in the public\graphs directory on the meteohub share.
Regarding wswin: are you sure that you have defined the correct sensors in the "WSWIN Data export" setup screen?
atlantique44
format
language 0
tf_mode 0
from_year 2011
from_mon 1
from_day 1
from_hour 0
from_min 0
to_year 2011
to_mon 1
to_day 4
to_hour 21
to_min 54
tr_ind 0
crop 0
xsize 610
ysize 300
fontsize 7
dspmode 0
left_unit 0
right_unit 0
left_measure 0
left_measuremin -10
left_measuremax 40
right_measure 0
right_measuremin -10
right_measuremax 40
left_gmode 4
right_gmode 4
left_sensors 1
left_sensor-0 th0-min (OUTDOOR)
left_sensorcolor-0 16711680
left_sensorname-0 TEMP_MIN
right_sensors 1
right_sensor-0 th0-max (OUTDOOR)
right_sensorcolor-0 49152
right_sensorname-0 TEMP_MAX
YJB wrote: Regarding wswin: are you sure that you have defined the correct sensors in the "WSWIN Data export" setup screen?
Could you do me a screenshot because I do not find this topic thank you very much
when you chosse a time resolution of 5 or 10 minutes, then you will not see a big difference between these. Choose "1 day" to get daily min/max curves.
YJB
Post by YJB »
Sure:
atlantique44
admin wrote:when you chosse a time resolution of 5 or 10 minutes, then you will not see a big difference between these. Choose "1 day" to get daily min/max curves.
thank you it works now
atlantique44
Sure:
yes J have the same thing so I think it must come from a setting in WSWIN
in your logciel WSWIN you have many minima and maxima of every day
