I receive a WMR100 weather station and I install the meteohub demo on a NSLU2.
Meteohub seems work fine on the NSLU2 and I can find the wrm weather station but I have a problem with the sensor :
I have the following message :
Warning: Weather station does not have a sensor assigned on "Sensors" page
Sensors are working well on the weather station
here the meteohub logfile :
logger (06.01.2011 23:48:46): connect station 0 (WMR-100/88 via USB HID).
wmr928fulleval(06.01.2011 23:50:01): recomputation of weather data started.
wmr928fulleval(06.01.2011 23:50:03): recomputation of weather data finished: 0 records processed in 2 seconds (0 records per second)
logger (06.01.2011 23:51:09): unexpected 0 bytes delivered from weather station 0 (WMR-100/88)
logger (06.01.2011 23:51:10): disconnect station 0 (WMR-100/88).
logger (06.01.2011 23:51:09): parent process received termination signal (15).
logger (06.01.2011 23:51:10): child process received termination signal (15).
logger (06.01.2011 23:51:12): data logger (version 4.7, build 215) started.
logger (06.01.2011 23:51:15): connect station 0 (WMR-100/88 via ).
logger (06.01.2011 23:51:15): child process received termination signal (11).
logger (06.01.2011 23:51:34): parent process received termination signal (15).
logger (06.01.2011 23:51:37): data logger (version 4.7, build 215) started.
logger (06.01.2011 23:51:40): connect station 0 (WMR-100/88 via USB HID).
logger (06.01.2011 23:53:51): parent process received termination signal (15).
logger (06.01.2011 23:53:51): child process received termination signal (15).
logger (06.01.2011 23:53:52): unexpected 0 bytes delivered from weather station 0 (WMR-100/88)
logger (06.01.2011 23:53:52): disconnect station 0 (WMR-100/88).
logger (06.01.2011 23:53:52): data logger stopped.
logger (06.01.2011 23:53:54): data logger (version 4.7, build 215) started.
logger (06.01.2011 23:53:57): connect station 0 (WMR-100/88 via USB HID).
wmr928fulleval(06.01.2011 23:55:01): recomputation of weather data started.
wmr928fulleval(06.01.2011 23:55:03): recomputation of weather data finished: 0 records processed in 2 seconds (0 records per second)
logger (06.01.2011 23:55:37): parent process received termination signal (15).
logger (06.01.2011 23:55:37): child process received termination signal (15).
logger (06.01.2011 23:55:37): unexpected 0 bytes delivered from weather station 0 (WMR-100/88)
logger (06.01.2011 23:55:37): disconnect station 0 (WMR-100/88).
logger (06.01.2011 23:55:37): data logger stopped.
logger (06.01.2011 23:55:41): data logger (version 4.7, build 215) started.
logger (06.01.2011 23:55:43): connect station 0 (WMR-100/88 via USB HID).
logger (06.01.2011 23:58:17): no signal from station 0 (WMR-100/88) for 150 seconds, station to be restarted.
logger (06.01.2011 23:58:18): disconnect station 0 (WMR-100/88).
logger (06.01.2011 23:58:48): connect station 0 (WMR-100/88 via USB HID).
wmr928fulleval(07.01.2011 00:00:01): recomputation of weather data started.
wmr928fulleval(07.01.2011 00:00:03): recomputation of weather data finished: 0 records processed in 1 seconds (0 records per second)
logger (07.01.2011 00:01:13): child process received timeout signal (14).
logger (07.01.2011 00:01:14): disconnect station 0 (WMR-100/88).
logger (07.01.2011 00:01:14): data logger stopped.
logger (07.01.2011 00:01:15): data logger (version 4.7, build 215) started.
logger (07.01.2011 00:01:17): connect station 0 (WMR-100/88 via USB HID).
logger (07.01.2011 00:03:50): no signal from station 0 (WMR-100/88) for 150 seconds, station to be restarted.
logger (07.01.2011 00:03:50): disconnect station 0 (WMR-100/88).
logger (07.01.2011 00:04:20): connect station 0 (WMR-100/88 via USB HID).
logger (07.01.2011 00:06:47): child process received timeout signal (14).
logger (07.01.2011 00:06:47): disconnect station 0 (WMR-100/88).
logger (07.01.2011 00:06:48): data logger stopped.
logger (07.01.2011 00:06:48): data logger (version 4.7, build 215) started.
logger (07.01.2011 00:06:51): connect station 0 (WMR-100/88 via USB HID).
logger (07.01.2011 00:09:24): no signal from station 0 (WMR-100/88) for 150 seconds, station to be restarted.
logger (07.01.2011 00:09:24): disconnect station 0 (WMR-100/88).
Thanks for your help
VPM
