WDL: Max wind and max gust are the same
markhiseman
Post by markhiseman »
I think I've spotted a bug in the information sent by Meteohub to WDL: the daily max windspeed and the max gust are always the same value as each other. See the wind speed instrument at the bottom of my webpage http://www.markhiseman.plus.com/Weather/.
I recently updated to Meteohub 4.7, and I don't think it used to do this. Can any other Meteohub/WDL users confirm this? Hopefully an easy fix.
Mark.
YJB
Re: WDL: Max wind and max gust are the same
Post by YJB »
Hmm, looks like you are right:
This is what it should be (and it was like that in previous versions):
71	Max Wind Gust	Knots [day1_wind0_gustspeedmax_kn:-]
113	Max Avg Speed	Knots [day1_wind0_speedmax_kn:-]
And this is what 4.7 is using:
113	Max Avg Speed	Knots [day1_wind0_gustspeedmax_kn:-]
Boris will need to fix this permanently.
In the mean time you can change the /home/meteohub/clientraw.conf file:
Assuming all your sensors are "0" sensors
Search for
[actual_th0_heatindex_c:-] [day1_wind0_gustspeedmax_kn:-]
And replace it with
[actual_th0_heatindex_c:-] [day1_wind0_speedmax_kn:-]
Ysbrand
field 113 will be changed as proposed by YJB with the next update.
markhiseman
Thanks to both of you (Boris: I assume you mean field 113 will be changed).
Mark.
yes, of course. just a typo. i already corrected that in the previous post.
markhiseman
Confirmed fixed in 4.7a. Thank you.
Mark.
