- switch to non-ssl connection when feeding weather network "meteonews" by a NSLU2 based Meteohub
- fix ssh-tunnel failure when requesting help via "help.cgi"
- fix XML syntax error in meteolog.cgi output
Update 4.7a
Update 4.7a
Update to Meteohub V4.7a (NSLU2, x86, SheevaPlug) brings some minor bug-fixes:
- Fresh Boarder
Re: Update 4.7a
Hello
excuse me for the translation because I am using translation software because I don not write English
When I am connected to the network place window with Meteohub as login and password I Meteohub No more has come to connect for the latest update to 4.7a is as if it was turning loop, I no longer happens access the file.
Thank you for your reply
- Senior Boarder
Re: Update 4.7a
Boris, I think atlantique44 is reporting the same issue that friese111 and I reported in the NSLU2 forum.
Mark.
Mark.
Re: Update 4.7a
Wish I of read this first!
I updated to 4.7a this morning and also can no longer log-in to meteohub via windows explorer (network share or via SSH)
I also have this in my smb server log:
[2011/01/18 17:16:38, 0] passdb/pdb_smbpasswd.c:build_sam_account(1202)
build_sam_account: smbpasswd database is corrupt! username meteohub with uid 500 is not in unix passwd database!
- Senior Boarder
Re: Update 4.7a
Yes, I have the same error in smblog.
Mark.
Mark.
- Fresh Boarder
Re: Update 4.7a
moi also la same Erreur
smb server log:
[2011/01/18 19:45:35, 0] passdb/pdb_smbpasswd.c:build_sam_account(1202)
smb server log:
- YJB
Re: Update 4.7a
Hmmm,
I can't check the share connection, since I'm travelling
What I do see on my Alix is that meteohub has disappeared from /etc/passwd:
The original version does return the meteohub user account:
I'm not sure if it would make sense to recreate a meteohub account, better wait for Boris to respond, he might have a very good reason for changing things.
WARNING:
If you want to modify /etc/passwd you will need to be careful in doing so. If you don't know exactly what you are doing you might loose access to your meteohub system. I've seen this happening more than once, so be careful.
meteohub:/etc# grep meteohub /etc/passwd
<nothing returned>
meteohub:/etc# grep meteohub /etc/passwd-
meteohub:x:1000:1000:meteohub,,,:/home/meteohub:/bin/bash
WARNING:
Re: Update 4.7a
yes, removing meteohub user from /etc/passwd is the root of the problem.
Will be fixed with next update (coming soon).
- Fresh Boarder
Re: Update 4.7a
Same happened to me, I can't access to pubic directory. So now I can't update my data in WSWIN or is there any workaround to solve this problem with actual firmware in short time? I distribute my data to a lot of other webpages and they have old data now... so please let me know how to solve this problem quickly! Thanks!
- Fresh Boarder
Re: Update 4.7a
I found this entry in the log:
[2011/01/19 14:58:19, 0] passdb/pdb_smbpasswd.c:build_sam_account(1202)
this entry is written several times per second... so ist this a known problem or only my own? thanks for any help!
- YJB
Re: Update 4.7a
Correct, this is a known problem that will be fixed by Boris in the next release, see the posting from Boris in this thread.
Re: Update 4.7a
It looks like anyone who updated to 4.7a is in the same boat.
It's a bit of a problem not having shares access, but at least MH is running correctly, so were not losing data.
Just have to wait for Boris to come up with a fix A.S.A.P.
- Fresh Boarder
Re: Update 4.7a
Yep, it looks like. But because I deliver data to many sites by WSWIN it's a very serious problem for me!! And so I hope for really fast support. At this time I could NOT ACCESS to my weatherbox with user meteohub?!! So I'm asking me how to upgrade or downgrade?! Here I have opened a browser where I still have access to weatherboxx becauase it seems there are working cookies or whatever, but if I try to connect from a different machine I could not connect with meteohub anymore... there is no user meteohub... ??YJB wrote:Correct, this is a known problem that will be fixed by Boris in the next release, see the posting from Boris in this thread.
- YJB
Re: Update 4.7a
As far as I know the access to the gui is not dependent on /etc/passwd so that's the reason you still have access to the web interface. As far as I can see, only share access is impacted (that is what the smb daemon is doing), web interface access, root access and ftp uploads are working as usual.
If you are familiar with *nix systems you can add the meteohub user back to the passwd file, but it's probably safer to wait until Boris has released the fix.
Also, if you feel that you meteohub installation is very important, it's better to wait a couple of days before upgrading. In that way you give others the opportunity to "test" without being impacted yourself. Also, the more experienced users can take the risk being early adopters of a new release, since they might be able to correct things on the fly.
- Fresh Boarder
Re: Update 4.7a
Last few times I already did it. And right when I do an installation for first time short after it's public, then such a f**** buttshit happens... You could be sure I have learned my lesson now... I NEVER will do an update before I consulted this forum and waited some days... !!YJB wrote:Also, if you feel that you meteohub installation is very important, it's better to wait a couple of days before upgrading. In that way you give others the opportunity to "test" without being impacted yourself. Also, the more experienced users can take the risk being early adopters of a new release, since they might be able to correct things on the fly.
