Update 4.7c
What's hot...
Update 4.7c
Update to Meteohub V4.7c (NSLU2, x86, SheevaPlug) brings these features:
  • Adds support for ebox3300MX (updated x86 install image).
  • Fixes a WD export bug that was introduced during making output of meteolog.cgi compliant to XML standard.
  • Feature to import WSWIN and Meteobase data by calling a URL. "http://ip-of-your-meteohub/cgi-bin/impo ... sv&alt=520" imports file "meteobase_2010.csv" located in "/public/transfer" as raw data. Altitude "520" (in meters) is needed as second parameter for sealevel pressure correction. Meteohub replaces raw data files for all months by a monthly import raw file. Therefore, be warned that existing data matching a month to be imported will be overwritten. Imported data gets date/time correction to be stored in UTC based on timzone defined for Meteohub. WSWIN files can be imported the same way. Import files need to be plain, uncompressed ASCII.
  • Reactivates user "meteohub" for ssh login, as some users do depend on this. Meteohub has two users to login via ssh: root and meteohub. Please change passwords on linux level to restrict access to these, when you allow ssh access (port 22) to your Meteohub.
  • WDL prints out vantage forecast text in German, when Meteohub language setting is German.
Update Link: http://www.meteohub.de/files/update-v4.7c.upd
cgn
Re: Update 4.7c
Post by cgn »
I tried to import a WSWIN file, but there is no sealevel pressure correction. It seems the "alt" parameter is without function.
Import with "alt=0" or "alt=100" or "alt=1000" gives the same pressure in the raw-file without correction.
I have updated to 4.7e.
Re: Update 4.7c
when both values #33 and #133 are in the import file, these are left unchanged. if only one is there, the other one is computed by given alt parameter.
