at first I really want to appreciate the work you've done on the meteohub software. It is a very nice software with so much functionality, that you can't use all features in one life.
But I also have a little problem with my meteohub. I installed it at an university's LAN where I can't change the router configuration. So, I won't be able to create a port-forwarding rule to my meteohub to get access to the configuration webpage from the Internet. Do you have any idea, how I can get access to the configuration webpage without port-forwarding? Would it be possible that the meteohub will create a vpn connection?
Thank you very much!
Akio
