Factory Reset
billbundy
Factory Reset
Post by billbundy »
How do I complete a factory reset of Meteohub2? I seem to have locked it up by assigning the new IP and or changing the Port #. It comes on with a green light, switches to red/green, then to red/blue, then goes back to green!! I have tried the reset button, but no luck... it will not come up on 192.168.1.77 any longer.
Re: Factory Reset
putting your browsing PC to 192.168.1 class c net and browsing to 192.168.1.77:7777 should work anyway.
You can't set a Meteohub to factory defaults - like you can't do with your computer ;-)
Last exit would be setting up the SD card from scratch as explained in Step 3 of Meteohub SheevaPlug manual: http://www.meteohub.de/files/How-To_Bui ... vaPlug.pdf
