La Crosse WS2300, EM1010PC and Alix.1D
Matrox
Post by Matrox »
I are now already for weeks to test.
Unfortunately I get neither the WS2300 with USB2Seriel PL2303, still the energy consumption measuring instrument ELV Em1010PC to run, since no connection can be developed. Property already tries to make me a Plugin for the WS2300. There I get however when starting:
 /home/ttt/ws2500: /lib/tls/libc.so.6: version `GLIBC_2.4' emergency found (required by /home/ttt/ws2500)
request, if someone sowas to run has, I would be grateful over information of any kind.
Greeting Jürgen
Hallo,
ich bin nun schon seit Wochen am testen.
Leider bekomme ich weder die WS2300 mit USB2Seriel PL2303,
noch das Energieverbrauchsmessgerät ELV Em1010PC
zu laufen, da keine Verbindung aufgebaut werden kann.
Habe auch schon versucht, mir ein Plugin für die WS2300 zu basteln.
Da bekomme ich aber beim Start:
/home/ttt/ws2500: /lib/tls/libc.so.6: version `GLIBC_2.4' not found (required by /home/ttt/ws2500)
Bitte, falls jemand sowas am laufen hat, wäre ich über Infos jeglicher Art dankbar.
Gruß
Jürgen
Re: La Crosse WS2300, EM1010PC and Alix.1D
are you using metohub?
Matrox
Post by Matrox »
Yes. :)
I have updatet to MeteoHub: 4.7f (Build 5302)
Energy monitor em1010 is directly supported by Meteohub. This works as any other weather station without need for tweaking installation.
PL2303 drivers are also there. WS2500 is not supported. May be you trashed some of the working code by trying to make WS2500 running?
WS2300 needs no plugin, but is directly supported. I don't understand why you try implementing a plugin for that?
I woul drecommend to do a fresh install and go with em1010 and ws2300 as provided by meteohub.
Matrox
Post by Matrox »
Ok, I will try a new installation and then will again report.
Than you for help and posting.
