Plugin for Newbies
Hathor27
Plugin for Newbies
Post by Hathor27 »
I'd like to plug additional weather-sensors to my meteohub. I read about in the manual, but can't get familiar with it.
  • One sensor I can reach thru http, where I should extract a string from the web-page (e.g. position 435, substring of 6 characters)
  • Another sensor comes from a HIOKI datalogger. Originally it has RS232. Meteohub has USB. Probably there is a RS232-USB-Convertor with a ready-made driver?
Can anybody help? Are there some sample plugins available or already made experiences? Thanks a lot in advance
Best Regards
Hathor27
http://untersiggenthal.meteodata.ch
Hathor27
Re: Plugin for Newbies
Post by Hathor27 »
Subject: Weather Station Plug-In example
admin wrote:This bash script is an example which pulls actual temperature data from a website (weather data of Sylt) and offers that to Meteohub:
#! /bin/sh
while :
do
  # pull data from website and filter the needed string
  wget -O /dev/stdout "http://www.wetter.com/deutschland/sylt_ost/DE0010330.html" 2>/dev/null | grep "deg text_l temp_w" | gawk 'BEGIN {FS=">"} {print $3}' | gawk 'BEGIN {FS="&"} {printf "t9 %d\n", lround ($1 * 10.0)}'
  # make sure output gets flushed
  sync
  # wait 30 seconds for next read
  sleep 30
done
Thanks to admin for your sample. Now I found time to analyze and have one more questions:
Can I somehow send the already recognized timestamp (read from the url of the station) with the measured value for t9 to meteohub? This because I want to save the original timestamp, not the one getting data into meteohub.
Something like
20071101145831 t9 258
Best Regards
Hathor27
yes, this is not formally documented, but when the line you transmit does start with a ":" then meteohub takes the number after that as a linux "time_t" typed date information (seconds since 1.1.1970).
Example ":1305913348 t9 123" gets interpreted as
Temp sensor #9 is reporting 12.3 °C at 2011-05-20 19:42:28 CEST.
wfpost
Post by wfpost »
hi boris,
tried to create an 3h barochange plugin based on your example, but it only works on the shell.
Your code works with my meteohub, but mine, despite working on the console when started manually showing up with the correct print-out, but fails to come up in the GUI. What could be the reason?
#! /bin/sh
while :
do
  # pull data filter the needed string
  nc localhost 5558 /dev/stdout 2>/dev/null | grep seqhour1_thb0_press_hpa | gawk 'BEGIN {FS="_"} {print $4,$7}' | gawk 'BEGIN {FS=" "} {printf "data9 %d\n", lround (($2 - $3) * 100.0) }'
  sync
  # wait 300 seconds for next read
  sleep 300
done
Do you do the sync thing to get things flushed to the listening stream?
wfpost
Post by wfpost »
yes, at least the sync command is in the shell script. The only thing I changed is the line where it reads the internal pressure value with nc.
When starting the shell script manually it shows the same bevaviour as your code:
It prints out the correct pair: sensor id + value. Exactly as with your example.
But for some reason it does not show up with the GUI. :roll:
wfpost
Post by wfpost »
seems it is nc, but why does it work when running manually as shell script?
logger (21.05.2011 08:57:23): connect station 3 (Plug-in via Plug-in).
logger (21.05.2011 08:57:23): error while doing write on socket 5558: Broken pipe
May be it needs a full qulified path. I don't know which environemnt is given the shell script when caled by Meteohub's logger.
Try "/bin/nc" instead of "nc" or check with "which nc" to find out where it is located on your system (may depend on used Meteohb platform).
another thought... Try using wget instead of nc:
wget -O - 127.0.0.1/meteograph.cgi?text=seqhour1_thb0_press_hpa 2>/dev/null
gets exactly the line of data you are looking for (no grep needed).
wfpost
Post by wfpost »
tried already the full path, but same error.
the thing with wget works, but I changed my earlier version a bit,
because the seqhour isn´t correct to calculate the 3H barotrend; as start pressure this value is needed:
actual_thb0_press_hpa
Can I feed stdout with two variables at once in a pipe?
Or even better: How are the changes to have an intrinsic solution:
a 3h barochange variable built into meteohub?
/bin/nc 192.168.1.112 5558 /dev/stdout 2>/dev/null | grep -E "actual_thb0_press_hpa|seqhour1_thb0_press_hpa" | gawk 'BEGIN {FS="_"} {print $4,$6}' | tr -s '\n' ' ' | gawk 'BEGIN {FS=" "} {printf "data9 %d\n", lround (($2 - $5) * 100.0) }'
wfpost wrote:Can I feed stdout with two variables at once in a pipe?
no, sorry.
wfpost
Post by wfpost »
these lines work:
#! /bin/sh
while :
do
wget -O /dev/stdout "http://192.168.1.112/meteograph.cgi?text=all" | grep -E "actual_thb0_press_hpa|seqhour1_thb0_press_hpa" | gawk 'BEGIN {FS="_"} {print $4,$6}' | tr -s '\n' ' ' | gawk 'BEGIN {FS=" "} {printf "data9 %d\n", lround (($2 - $5) * 100.0) }'
  sync
  # wait 900 seconds for next read
  sleep 900
done
20110521120715 thb0 21.4 52 11.1 944.8 1018.6 2
20110521120755 th0 23.3 48 11.7
20110521120745 uv0 6.3
20110521120735 sol0 882
20110521120737 wind0 71 0.0 1.8 23.3
20110521120709 rain0 0.0 178.4 0.0
20110521120747 th1 21.2 53 11.2
20110521120749 t2 -22.9
20110521120750 t0 14.1
20110521120744 th2 23.0 45 10.4
20110521120804 th4 31.7 10 -3.7
20110521120724 th5 15.1 79 11.5
20110521120757 th3 26.9 44 13.6
20110521120801 data0 3.88
20110521120801 data1 45406.00
20110521120801 data3 0.91
20110521120801 data2 0.40
20110521120801 data4 0.01
20110521120801 data5 68.00
20110521120801 data6 3.00
20110521120801 data7 1.00
20110521120801 data8 0.20
20110521120634 data9 -1.60 <<<----- 3h pressure change in hPa
20110521120704 t7 23.6
Hathor27
Post by Hathor27 »
Hi there,
wfpost wrote:hi boris,
I noticed the same behaviour with admins sample with wget...
#! /bin/sh
while :
do
  sync
  sleep 30
done
What is the difference? Just the sleep 300 ?
Best Regards
Hathor27
wfpost
Post by wfpost »
boris sample is working with my meteohub.
the sleep value can´t be the culprit, I guess
30s is not a reasonable polling value anyway, because the website updates the temps every 20-30 minutes
What error do you get?
sleep value should be shorter than "data hold time" defined on "weather station" page for that particular station.
