I am getting this error;
weathernet: No data upload to weather networks as sensor selected on weather network page for outdoor temp, outdoor humidity or outdoor dewpoint is not providing recent data.:
All of my sensors are showing data and all recent. I've tried all sorts of changes. Is there a better way to isolate this ?
Error message
Re: Error message
plaease post your settings of "weather network" page.
Re: Error message
Nothing selected until the weatherbug section.
WeatherBug ID p10591 Num 22187 Password *******
Selection of sensors to be used
Outdoor Temperature th0(Outdoor) Pressure thb0(Console)
Outdoor Humidity th0(Outdoor) Wind wind0(Wind)
Dew Point Rain rain0(RainGauge)
UV Index Solar
Indoor Temperature
Temp. #2 Temp. #3
Temp. #4 Temp. #5
Temp. #6 Temp. #7
Frequency of Updates
Update every 5 Min
Station 0 (WH-1080): LLPS
Type # ID Name Last Signal Sensor Data
wind 0 wind0(Wind) 5 sec 2.7(1.7)m/s S
rain 0 rain0 (RainGauge) 5 sec 0.0mm/h
indoor 0 thb0 (Console) 5 sec 25.9° 53% 1012.3mb (1012.7mb) fc:-1
outdoor 0 th0 (Outdoor) 5 sec 27.7° 79%
Virtual Sensors
New ID Name Trigger Conversion Last Signal Sensor Data
UV Index Solar
Indoor Temperature
Temp. #2 Temp. #3
Temp. #4 Temp. #5
Temp. #6 Temp. #7
Update every 5 Min
Virtual Sensors
Re: Error message
I also realized I am in the wrong forum.......
But I have one other odd error message
Mail send failed: /home/meteohub/esmtprc:3: syntax error at end of input
Re: Error message
"dew point" needs a sensor setting, should be "th0" with your setup.wdicken wrote:Dew Point Rain rain0(RainGauge)
Re: Error message
Thank you. I did finally get it. Thanks again.
