New supported Hardware: DreamPlug
What's hot...
This is just to let you know that I am working on a port of the SheevaPlug successor, called DreamPlug, from Globalscale.
Porting works fine so far. It will need a different SD card image, but overall changes compared to SheevaPlug are not that spectacular.
US: http://www.globalscaletechnologies.com/ ... evkit.aspx
Europe: http://www.newit.co.uk/shop/proddetail. ... =DreamPlug
Advantages of DreamPlug compared to SheevaPlug are:
- integrated SD card slot, SD card no longer sticking out, more reliable mechanical solution
- integrated WLAN
- two USB ports
- DreamPlug offers more connectors/jacks (e-sata, mic, headphone, 2nd ethernet, bluetooth) but Meteohub does not make use of these
Disadvantages:
- costs 149 USD (instead of 99 USD for SheevaPlug)
When port is finalized you will get instructions/downloads how to configure a DreamPlug to become a Meteohub.
Stay tuned...
Re: New supported Hardware: DreamPlug
The port is done. Even WLAN (although being a SDIO connected device, nit PCI or USB as usually) is working! :D
Meteohub Website is also updated to reflect this new option. Details how to transform a DreamPlug into a Meteohub can be found here:
http://www.meteohub.de/files/How-To_Bui ... amPlug.pdf
From just released version 4.7g on, Meteohub updates will support DreamPlug as a new family member.
rigel
Post by rigel »
Great to see this. Does this also work with GuruPlug? if not, should we assume there will be no port in the future for GuruPlug? thanks
there will be no guruplug port. i have a guruplug plus but this suffered so much from heat problems that i decided not to port. dreamplug looks like a much better second gen sheevaplug to me, although i find it a bit pricy. but formfactor, a fully physically integrated sd card slot and the integrated wlan are on the plus side.
stefferber
Post by stefferber »
I am running the DreamPlug for 11 days now and I am really happy. I can recommend to order it with preinstalled meteohub software. One more advantage with the DreamPlug is that you can detach the power supply. Then it is not plugged directly to a socket and can be mounted somewhere.
where do you get it with meteohub preinstalled?
stefferber
I got it from NewIT in UK.
stefferber
I am using my DreamPlug happly since the last posts above. But as Debian Lenny is not supported any more I encounter some problems now adding new software e.g. perl is outdated with perl 5.10.0-19l
I am using now these package sources in /etc/apt/source.list
deb http://ftp.de.debian.org/debian-archive/debian/ lenny main
deb-src http://ftp.de.debian.org/debian-archive/debian/ lenny main
The following repository is "lost in space"
# Orion repository
#deb http://people.debian.org/~tbm/orion lenny main
Any idea what's it for and where it is now?
Does anybody have some experience to switch from Debian Lenny to Debian Wheezy via apt-get?
Or do I need a complete new image to do that?
Is there a DreamPlug, Debian Wheezy, Meteohub image available somewhere?
I tried to test a bit in a virtual machine but could not make my dream plug image run in my Oracle Virtual Box VM. And the available Meteohub VM is much different from my dream plug installation...
stefferber
Updating to Debian Wheezy looks a little bit more complicated than I thought.
Getting a new Debian image for the dreamplug is easy. This you can download Debian Squeeze or Debian Wheezy here
https://newit.co.uk/forum/index.php/topic,2491.0.html
Or you can even by a new SD card with pre-installed Debian Wheezy:
http://www.newit.co.uk/shop/All-DreamPl ... ?limit=100
As I have a pre-installed meteohub SD card on my dreamplug, the dreamplug already boots from the external SD card /dev/sdb :
# less /etc/fstab
# /etc/fstab: static file system information.
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
proc            /proc           proc    defaults        0       0
/dev/sdb2       /               ext3    noatime,errors=remount-ro,commit=120 0       1
/dev/sdb3       none            swap    sw               0       1
/dev/sdb4       /data           ext3    noatime,errors=remount-ro,commit=120 0       1
tmpfs           /var/lock       tmpfs   mode=755,size=8M        0       0
tmpfs           /var/run        tmpfs   mode=755,size=32M        0       0
tmpfs           /var/log        tmpfs   mode=755,size=32M       0       0
mars:/home      /server         nfs     noauto
The internal micro SD card /dev/sda is not used at all
# ls -l /dev/sd*
brw-rw---- 1 root floppy 8,  0 Sep  8 10:03 /dev/sda
brw-rw---- 1 root floppy 8,  1 Sep  8 10:03 /dev/sda1
brw-rw---- 1 root floppy 8,  2 Sep  8 10:03 /dev/sda2
brw-rw---- 1 root floppy 8, 16 Sep  8 10:03 /dev/sdb
brw-rw---- 1 root floppy 8, 17 Sep  8 10:03 /dev/sdb1
brw-rw---- 1 root floppy 8, 18 Sep  8 10:03 /dev/sdb2
brw-rw---- 1 root floppy 8, 19 Sep  8 10:03 /dev/sdb3
brw-rw---- 1 root floppy 8, 20 Sep  8 10:03 /dev/sdb4
Which is really a pity as all the free memory space of the internal SD card is not used:
Filesystem            Size  Used Avail Use% Mounted on
/dev/sda2             3.6G  539M  2.9G  16% /tmp/filesystem-sda2
The meteohub ready made image is a 4GB Debian Lenny
http://wiki.meteohub.de/Images
Well anyway. My final questions remains:
How do I install all the meteohub specific files on top of the 16GB Debian Wheezy Image?
There is no simple 1-2-3 to achieve that and I would not recommend
spending hours on that. Even if you succeed in setting it up, i wont
expect Meteohub updates doing proper work on that anymore.
Of course you can do as you like, but please understand that I cannot
recommend such individual changes that will open the door to "support hell".
You are on your own here.
stefferber
My manual migration to squeeze is under way. The only and big issue is the change of boot sequence. During the distribution upgrade I get
apt-get update
apt-get dist-upgrade
Unable to migrate to dependency-based boot system
Tests have determined that problems in the boot system exist which
prevent migration to dependency-based boot sequencing:
insserv: warning: script 'K20loggerd' missing LSB tags and overrides,
insserv: warning: script 'K20ddclient' missing LSB tags and overrides,
insserv: warning: script 'loggerd' missing LSB tags and overrides,
insserv: script rsync: service rsyncd already  provided!,
insserv: warning: script 'ddclient' missing LSB tags and overrides, ,
package at removed but not purged, package exim4-base removed but not purged
If the reported problem is a local modification, it needs to be fixed
manually. If it's a bug in the package, it should be reported to the
BTS and fixed in the package. See
http://wiki.debian.org/LSBInitScripts/DependencyBasedBoot for more
information about how to fix the problems preventing migration.
To reattempt the migration process after the problems have been fixed,
run "dpkg-reconfigure sysv-rc".
The files are located here
/etc/rc0.d/K20loggerd
/etc/rc1.d/K20loggerd
/etc/rc6.d/K20loggerd
/etc/rc0.d/K20ddclient
/etc/rc1.d/K20ddclient
/etc/rc6.d/K20ddclient
/etc/init.d/loggerd
/etc/init.d/ddclient
/etc/default/ddclient
/etc/ppp/ip-up.d/ddclient
Looks I solved the 'ddclient' by unpacking the file 'd_ddclient.lsb" by hand.
But where do the other files come from?
Looks like openembedded and meteohub?
Any idea how to add the LSB conform commands to these scripts?
stefferber
In order to migrate I simply removed the "rsyncd" and "loggerd" boot script and successfully made it to Debian Squeeze:
meteoplug:~# lsb_release -a
No LSB modules are available.
Distributor ID:	Debian
Description:	Debian GNU/Linux 6.0.7 (squeeze)
Release:	6.0.7
Codename:	squeeze
After rebooting I copied the start scripts back to /etc/init.d/ and started the two services by hand:
/etc/init.d/rsyncd start
/etc/init.d/loggerd start
Meteohub sensor data is collected but I receive this error message in the "system info" menus
Error file open: /var/run/dropbear.pid: No such file or directory
Error file open: /var/run/smbd.pid: No such file or directory
Weather Data Recomputation:	completed
Weather Data Logging:	running (last data: never)
SSH Login:	stopped
SMB Shares:	stopped
Time Synchonization:	running
Looks like samba does not work. But there is something else wrong, isn't it?
stefferber
So finally I gave up to migrate the linux distribution completely.
I only installed exactly the debian packages that I needed for node.js which requires python which requires g++ which requires …
This requires to use
apt-get install nodejs
apt-get install npm
and multiple changes in the "/etc/apt/source.list" to multiple debian distributions in order to get the exact version of a package. Well about 5h of hacking ;-)
