Hi!
There was heavy rain and something caused my Sheeva to stop collection rainfall data. All other sensors worked fine (wmr200). About 2 hours after the fail I recognized the problem and restarted the data-collecting-process. Rain0 was found again and nearly everything was fine.
Except that there were 300 mm of total rainfall (there is a factor 0.21 because of some changes at the gauge) - I think max. 30 mm should be ok for this period.
As you see in the attached image (last column) the calculations are correct.
And now my question: how can I get rid of these 300 mm?
I guess I can't change the raw-data because every time there is a recalculation the difference between 99985 and 114442 will be included in the total rainfall - right?
So what can be done - and thanks for answering!
total rainfall
total rainfall
- rainfall.jpg (40.79 KiB) Viewed 2684 times
Re: total rainfall
mark the rain data set before the increase and the first one showing the increase as deleted (on "inspect data" page). Do a recomputation and it should be fine.
Re: total rainfall
worked - thanks!
