Backup data ...waiting
algol
Post by algol »
I migrated from NSLU2 to Alix 1d.
When trying to restore data from file meteohub.backup (.../public/meteohub.backup - size 7,5mb, half year data) on the system info page shows
Weather Data Recomputation: waiting
This is my second attempt. In the first attempt the system was "waiting" for 4 days - too long i think? or not?
Is possible that there are some errors in data?
Re: Backup data ...waiting
1) Please inspect log files ("meteohub log") for errors to get a clue what the problem is.
2) does a reboot fix the situation?
algol
Post by algol »
2.) i tried to reboot many times but nothing changed,
1.) this is my meteohub log, after new installation
___________________________________________________________________________
logger (22.06.2011 21:16:26): data logger (version 4.7, build 4935) started.
wmr928fulleval(22.06.2011 19:40:01): recomputation of weather data started.
wmr928fulleval(22.06.2011 19:40:02): recomputation of weather data finished: 0 records processed in 1 seconds (0 records per second)
logger (22.06.2011 19:42:15): child process received timeout signal (14).
logger (22.06.2011 19:42:15): data logger stopped.
logger (22.06.2011 19:42:15): data logger (version 4.7, build 4935) started.
logger (22.06.2011 19:47:46): child process received timeout signal (14).
logger (22.06.2011 19:47:46): data logger stopped.
logger (22.06.2011 19:47:46): data logger (version 4.7, build 4935) started.
logger (22.06.2011 19:53:16): child process received timeout signal (14).
logger (22.06.2011 19:53:16): data logger stopped.
logger (22.06.2011 19:53:16): data logger (version 4.7, build 4935) started.
logger (22.06.2011 19:56:38): parent process received termination signal (15).
logger (22.06.2011 19:56:38): child process received termination signal (15).
logger (22.06.2011 19:56:43): data logger stopped.
logger (22.06.2011 19:56:44): data logger (version 4.7, build 4935) started.
logger (22.06.2011 19:56:44): station 0 (WMR-928), can't set attributes of device x: Bad file descriptor
logger (22.06.2011 19:57:18): station 0 (WMR-928), can't set attributes of device x: Bad file descriptor
logger (22.06.2011 19:57:48): station 0 (WMR-928), can't set attributes of device x: Bad file descriptor
logger (22.06.2011 19:58:18): station 0 (WMR-928), can't set attributes of device x: Bad file descriptor
logger (22.06.2011 19:58:48): station 0 (WMR-928), can't set attributes of device x: Bad file descriptor
logger (22.06.2011 19:59:18): station 0 (WMR-928), can't set attributes of device x: Bad file descriptor
logger (22.06.2011 19:59:49): station 0 (WMR-928), can't set attributes of device x: Bad file descriptor
logger (22.06.2011 20:00:10): parent process received termination signal (15).
logger (22.06.2011 20:00:10): child process received termination signal (15).
logger (22.06.2011 20:00:14): data logger stopped.
logger (22.06.2011 20:00:15): data logger (version 4.7, build 4935) started.
logger (22.06.2011 20:00:16): connect station 0 (WMR-928 via USB serial).
logger (22.06.2011 21:29:32): parent process received termination signal (15).
logger (22.06.2011 21:29:32): child process received termination signal (15).
logger (22.06.2011 21:29:36): disconnect station 0 (WMR-928).
logger (22.06.2011 21:29:36): data logger stopped.
logger (22.06.2011 21:29:37): data logger (version 4.7, build 4935) started.
logger (22.06.2011 21:29:37): connect station 0 (WMR-928 via USB serial).
wmr928fulleval(22.06.2011 21:30:01): recomputation of weather data started.
wmr928fulleval(22.06.2011 21:30:01): recomputation of weather data finished: 0 records processed in 0 seconds ( records per second)
logger (22.06.2011 21:30:15): parent process received termination signal (15).
logger (22.06.2011 21:30:15): child process received termination signal (15).
logger (22.06.2011 21:30:16): disconnect station 0 (WMR-928).
logger (22.06.2011 21:30:16): data logger stopped.
logger (22.06.2011 21:30:17): data logger (version 4.7, build 4935) started.
logger (22.06.2011 21:30:18): connect station 0 (WMR-928 via USB serial).
wmr928fulleval(22.06.2011 21:35:01): recomputation of weather data started.
wmr928fulleval(22.06.2011 21:35:01): recomputation of weather data finished: 31 records processed in 0 seconds ( records per second)
Thu Jun 23 07:38:17 CEST 2011: full restore started...
tar: data/meteohub.backup: Cannot open: No such file or directory
tar: Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error exit delayed from previous errors
Thu Jun 23 07:38:17 CEST 2011: full restore done.
logger (23.06.2011 07:38:21): parent process received termination signal (15).
logger (23.06.2011 07:38:21): child process received termination signal (15).
logger (23.06.2011 07:39:22): data logger (version 4.7, build 4935) started.
logger (23.06.2011 07:39:23): connect station 0 (WMR-928 via USB serial).
wmr928fulleval(23.06.2011 07:40:02): recomputation of weather data started.
wmr928fulleval(23.06.2011 07:40:05): recomputation of weather data finished: 5114 records processed in 3 seconds (1704 records per second)
Thu Jun 23 07:42:06 CEST 2011: full restore started...
Thu Jun 23 07:42:15 CEST 2011: full restore done.
logger (23.06.2011 07:42:29): parent process received termination signal (15).
logger (23.06.2011 07:42:29): child process received termination signal (15).
logger (23.06.2011 07:42:31): disconnect station 0 (WMR-928).
logger (23.06.2011 07:42:31): data logger stopped.
logger (23.06.2011 07:43:31): data logger (version 4.7, build 4935) started.
logger (23.06.2011 07:43:32): connect station 0 (WMR-928 via USB serial).
logger (23.06.2011 17:31:53): parent process received termination signal (15).
logger (23.06.2011 17:31:53): child process received termination signal (15).
logger (23.06.2011 17:31:54): disconnect station 0 (WMR-928).
logger (23.06.2011 17:31:54): data logger stopped.
logger (23.06.2011 17:32:55): data logger (version 4.7, build 4935) started.
logger (23.06.2011 17:32:56): connect station 0 (WMR-928 via USB serial).
___________________________________________________________________________________
Thanks for help
